Anyhow, it works, tx side seems to be fine, my big problem is on the rx side each output that is a if/then statement will come on but when I release the button it stays on. The only way to make it turn off is to press another momentary button. The toggle function works fine, although if I hold onto the button to long it will toggle on/off. if/then example I have tried after Skimask post:
Debouncing isn't going to work very well without a 'switch' to actually debounce. If you're trying to debounce a received signal, I don't think that it's the right way to go about it.
This shouldn't be all that hard...but if you continue having problems, you might want to thinking about sending MAKE and BREAK codes with the TX similar to a PC keyboard.
I.E. code1 = button 1 pressed
code2 = button 1 released
code3 = button 2 pressed....
and so on and so on...
