RS232 to RS485
Results 1 to 23 of 23
Thread: RS232 to RS485
    Jun 2007
    Mansfield, UK
    It turns out it was a programming problem. As the chips start up the first one sends out a byte to tell the others how many chanels it has then goes into receive mode. The second one then does the same thing but the byte it sends out gets counted as data by the first light. Im really not sure why it was sometimes 2 extra bytes but ive reprogrammed it and it seems to be working perfect now. Sorry for wasting your time
    Dec 2005
    You're now an expert who can help the next RS485 noob.
    Jun 2007
    Mansfield, UK
    Haha, I wouldnt say 'expert'. Remember im the one who just got it wrong. I havnt tested with long wires yet so no doubt ill have more problems
    Quote Originally Posted by The Master View Post
    If you're using drivers designed for '485 and you design the circuit within the '485 specs, why would you have problems with long wires? Shouldn't... Could happen...but shouldn't...
    Jun 2007
    Mansfield, UK
    It "could happen" so it probably will the first time i try it. Im almost out of CAT5 cable so i guess it wouldnt hurt to buy another box and test it over the full length (about 300m). Ive just been reading a page about some of the things that can go wrong but i think ive got most of them covered. There might be a problem if the main box isnt connected because none of the lights bias the line themselves. I think thats a good thing because aparently too many devices biasing the line can stop data from being transmitted. Once the main box is connected they all need turning off and back on again before they can work anyway.
    Another idea is to put the biasing resistors in the terminating plug. Its possible because once the lights are turned on there will be both positive and negative voltages coming out of the socket. I doubt ill need to do that though
    I would like to connect up way more MAX485's than the specification allows and see how many it takes to stop it working just to make sure everything will be fine. I think the limit was about 30 unless i have those other ones that allow 128. I might need a bigger breadboard for that :P
  1. UART vs software RS232
    By Michael in forum mel PIC BASIC Pro
    Last Post: - 5th September 2008, 19:27
  2. RS232 into 2 PC ports
    By manxman in forum mel PIC BASIC Pro
    Last Post: - 30th August 2008, 14:33
  3. PIC18F4680 to PC via MAX232 (RS232 serial) no output
    By opticsteam1 in forum mel PIC BASIC Pro
    Last Post: - 14th April 2008, 21:39
  4. Using 16f676 with comms
    By Peter1960 in forum mel PIC BASIC Pro
    Last Post: - 28th October 2005, 21:01
  5. rs485 to rs232 smart switch
    By RSSHARPE in forum mel PIC BASIC Pro
    Last Post: - 17th June 2004, 09:44
