16f887a
Results 1 to 7 of 7
Thread: 16f887a
    Here is a circuit and project;
    http://rentron.com/PICX1.htm
    The data sheet helps too
    Jun 2008
    Yea, the problem was an external osc.
    I succeded to use a 8Mhz (also need to define that in the code), but for some reson 20Mhz doesn't work.
    Thank,
    Menta
    Do you have the config set HS_OSC or something like that.
