Still Experimenting
Results 1 to 3 of 3
    Quote Originally Posted by tazntex View Post
    Is there any way when I send my data to the receiver I need it recognize that I am still pressing the switch and hold an output high but once the switch is released the output is to go low? Here is my receiver code:
    Think yourself thru the code...
    If I'm still receiving a code that a switch is pressed, hold the output high and check again
    If I'm not receiving the code mentioned above, put the output low and check again
    Simple as that...
    Well, I'm about to pull all the hair out of my head. I've tried several things including something like this:
    rly1:
    if mydata=%00000000 then high 7
    pause 250
    IF mydata<>%00000000 then low 7
    goto loop
    Still no go and the next loop:
    rly2:
    HIGH 6
    pause 250
    Low 6
    goto loop
    of course while I pressing the button down on the transmitter rly2 just goes on/off,etc.
    I've been going through the compiler manual again trying to figure out what I am missing. Any more tips? Thanks
  1. Experimenting with the PicBasic Pro Compiler
    By polymer52 in forum mel PIC BASIC Pro
    Last Post: - 17th May 2016, 19:17
  2. Replies: 7
    Last Post: - 17th May 2016, 19:03
  3. Replies: 2
    Last Post: - 8th March 2009, 22:32
  4. UPS serial protocol
    By sougata in forum mel PIC BASIC Pro
    Last Post: - 5th November 2006, 02:49
  5. Experimenting With Pic Basic Pro Question
    By jabahunter in forum mel PIC BASIC Pro
    Last Post: - 28th May 2005, 08:16
