ds18s20 reads incorectly
Results 1 to 40 of 43
    May 2008
    Florida
    Jack
    The reason your PBP version did not work was because:
    You attempted to convert C to F using the RAW temp from the DS18S20.
    TEMP = ((TEMP*9/5)+32 )
    Then tried to calculate the temp from the results.
    Lcdout $fe, 1, dec (temp >> 1),".",dec(temp.0 * 5)," degrees C"
    For the fun of it lets plug some numbers in assume 27.5 C is the temp today.
    From the datasheet : The temperature sensor output has 9-bit resolution, which corresponds to 0.5°C steps.
    so 27.5*2 = 55
    Temp = (55*9/5) + 32 = 131
    So Temp now is equal to 131.
    Next we shift right 131>>1 same as temp/2 = 65.5
    Hmmm 65.535 does that number ring a bell?
    Wonder what would happen if you were to shift first then convert C to F like all of the other code posted does?
    temp = (temp>>1*9/5) +32 = (27.5*9/5)+32 = 81.5 F
    Hopefully this explains to you why it works in MikroBasic and not in PBP. The math is not broken, just the order of operation.
    That is why I said check math, simple change would fix it.
    Acetronic: I ask because you posted for jcleaver, would not take without asking first.
    Quote Originally Posted by manwolf View Post
    Nice find. I should've caught that the first time around.
    May 2008
    Florida
    Red face
    Beginners luck.
  1. DS18B20 VS DS18S20 & multiple
    Last Post: - 7th February 2008, 23:43
  2. Using A Ds18s20 And Servo
    By CrazyCooter in forum mel PIC BASIC Pro
    Last Post: - 12th September 2007, 10:41
  3. DS18S20 displays wrong temperatures
    By Shozo Kanamori in forum mel PIC BASIC Pro
    Last Post: - 6th August 2007, 04:18
  4. DS18s20 - negative teperature
    By Ceug2005 in forum mel PIC BASIC Pro
    Last Post: - 2nd February 2005, 13:40
  5. 16F877, DS18S20 and Serial Comm Problem
    By YellowTang in forum mel PIC BASIC Pro
    Last Post: - 26th April 2004, 11:36
