This code works great and gives the correct temperature throughout the sensors range in both Fahrenheit and Celsius. The format is like this: TempC = 2250 = 22.50ºC, TempF = 7250 = 72.50ºF.
Code:ReadDS18S20: owout sensor,1,[$CC, $44] ' Send Start Temperature Conversion command owout sensor,1,[$CC, $BE] ' Send Read Temperature command owin sensor,0,[STR dq\9] ' Retrieve all 9 bytes of data RawTemp.Byte0 = dq[0] RawTemp.byte1 = dq[1] if RawTemp.8 = 1 then ' Check if temperature is a negative reading SignC = Negative RawTemp.lowbyte = RawTemp.lowbyte ^ 255 ' Invert data else SignC = Positive endif dummy = RawTemp.0 ' Store the half degree indicator bit TempC = ((RawTemp.lowbyte) >> 1) * 100 ' Divide raw data by 2 to give real temperature TempC = TempC + (dummy * 50) ' Add the half degree is present if SignC = Negative then ' Only proceed if temperature is negative if TempC => 1770 then SignF = Negative TempF = (TempC + 5000) * 900 TempF = div32 500 TempF = TempF - 12200 return else SignF = Positive TempF = (TempC + 5000) * 900 TempF = div32 500 TempF = 12200 - TempF return endif endif SignF = Positive TempF = TempC * 18 / 10 + 3200 return
Jack
The reason your PBP version did not work was because:
You attempted to convert C to F using the RAW temp from the DS18S20.
TEMP = ((TEMP*9/5)+32 )
Then tried to calculate the temp from the results.
Lcdout $fe, 1, dec (temp >> 1),".",dec(temp.0 * 5)," degrees C"
For the fun of it lets plug some numbers in assume 27.5 C is the temp today.
From the datasheet : The temperature sensor output has 9-bit resolution, which corresponds to 0.5°C steps.
so 27.5*2 = 55
Temp = (55*9/5) + 32 = 131
So Temp now is equal to 131.
Next we shift right 131>>1 same as temp/2 = 65.5
Hmmm 65.535 does that number ring a bell?
Wonder what would happen if you were to shift first then convert C to F like all of the other code posted does?
temp = (temp>>1*9/5) +32 = (27.5*9/5)+32 = 81.5 F
Hopefully this explains to you why it works in MikroBasic and not in PBP. The math is not broken, just the order of operation.
That is why I said check math, simple change would fix it.
Acetronic: I ask because you posted for jcleaver, would not take without asking first.![]()
I am trying to follow your code in an effort to better understand it, but I don't understand
SignC = Positive
It would help if you shared the declarations of the variables used.Code:ReadDS18S20: owout sensor,1,[$CC, $44] ' Send Start Temperature Conversion command owout sensor,1,[$CC, $BE] ' Send Read Temperature command owin sensor,0,[STR dq\9] ' Retrieve all 9 bytes of data RawTemp.Byte0 = dq[0] RawTemp.byte1 = dq[1] if RawTemp.8 = 1 then ' Check if temperature is a negative reading SignC = Negative RawTemp.lowbyte = RawTemp.lowbyte ^ 255 ' Invert data else SignC = Positive endif dummy = RawTemp.0 ' Store the half degree indicator bit TempC = ((RawTemp.lowbyte) >> 1) * 100 ' Divide raw data by 2 to give real temperature TempC = TempC + (dummy * 50) ' Add the half degree is present if SignC = Negative then ' Only proceed if temperature is negative if TempC => 1770 then SignF = Negative TempF = (TempC + 5000) * 900 TempF = div32 500 TempF = TempF - 12200 return else SignF = Positive TempF = (TempC + 5000) * 900 TempF = div32 500 TempF = 12200 - TempF return endif endif SignF = Positive TempF = TempC * 18 / 10 + 3200 return
sensor equates to the hardware pin connected to the sensor?
RawTemp is a word?
dq is an array of 9?
dummy is a byte?
TempC is a byte?
TempF is a byte?
I don't get SignC or SignF and how you can equate to 'Positive' or 'Negative', I couldn't find a reference in the PBP manual.
Explanation would be appreciated.
"If we knew what we were doing, it wouldn't be called research"
- Albert Einstein
For positive temperatures the output increases from 0000h as the temperature increases from 0 deg C.I don't get SignC or SignF and how you can equate to 'Positive' or 'Negative', I couldn't find a reference in the PBP manual.
For negative temperatures the output decreases from FFFFh as the temperature falls below -0.5 deg C.
To check for negative any output bit can be checked for 1, when that bit is outside the temperature range of the sensor. The data sheet says
The sign bit (S) indicates if the value is positive or negative: for positive numbers S = 0 and for negative numbers S = 1.
In the program RawTemp.8 is chosen as the sign bit.
Steve Earl www.datageo.co.uk
Thanks EarlyBird2, I did figure that part out. In the code that the 'Kid' supplied, I could not get it to work until I remarked the SignC=Negative portion.
The code below works, but I have not tried for negative numbers yet..... Could you explain why?
Thanks and Regards,
Code:ReadDS18S20:' Works, mostly.....------------------------------------------------ owout Tsensor,1,[$CC, $44] 'Send Start Temperature Conversion command owout Tsensor,1,[$CC, $BE] 'Send Read Temperature command owin Tsensor,0,[STR dq\9] 'Retrieve all 9 bytes of data RawTemp.Byte0 = dq[0] RawTemp.byte1 = dq[1] if RawTemp.8 = 1 then 'Check if temperature is a negative reading SignC = Negative RawTemp.lowbyte = RawTemp.lowbyte ^ 255 'Invert data else SignC = Positive endif dummy = RawTemp.0 'Store the half degree indicator bit TempC = ((RawTemp.lowbyte) >> 1) * 100 'Divide raw data by 2 to give real temperature TempC = TempC + (dummy * 50) 'Add the half degree is present ' if SignC = Negative then 'Only proceed if temperature is negative - doesnt work for F, fine for C ' if TempC => 1770 then ' SignF = Negative ' TempF = (TempC + 5000) * 900 ' TempF = div32 500 ' TempF = TempF - 12200 ' return ' else ' SignF = Positive ' TempF = (TempC + 5000) * 900 ' TempF = div32 500 ' TempF = 12200 - TempF ' return ' endif ' endif SignF = Positive 'Sign is + TempF = ((TempC * 18) / 10) + 3200 'Convert from C to F return
- Albert Einstein
Negative and Positive are declared variables or constants. In your code should be
Negative CON 1
Positive CON 0
Does this help?
Could be SYMBOL or ALIAS of course.
EarlyBird2-
Thanks! I just tried it (I did NOT have them as CONstants), compiles fine but still gives me 0.00F.
Code is below for clarification.
This what I have that does work, just not for negatives.....Code:Positive con 0 'Bit used for + in the DS18S20 Negative con 1 'Bit used for - in the DS18S20 rawtemp var word 'Raw temp var tempC var word 'Temp var for degrees C tempF var word 'Temp var for degrees F dq var byte[9] 'String of data from DS18S20 SignC var bit 'Bit for + or - for degrees C SignF var bit 'Bit for + or - for degrees F dummy var bit 'Temp var ReadDS18S20:' Works, mostly.....--Thanks 'Kid' from Forum----------------------- owout Tsensor,1,[$CC, $44] 'Send Start Temperature Conversion command owout Tsensor,1,[$CC, $BE] 'Send Read Temperature command owin Tsensor,0,[STR dq\9] 'Retrieve all 9 bytes of data RawTemp.Byte0 = dq[0] RawTemp.byte1 = dq[1] if RawTemp.8 = 1 then 'Check if temperature is a negative reading SignC = Negative RawTemp.lowbyte = RawTemp.lowbyte ^ 255 'Invert data else SignC = Positive endif dummy = RawTemp.0 'Store the half degree indicator bit TempC = ((RawTemp.lowbyte) >> 1) * 100 'Divide raw data by 2 to give real temperature TempC = TempC + (dummy * 50) 'Add the half degree is present if SignC = Negative then 'Only proceed if temperature is negative - doesnt work for F, fine for C if TempC => 1770 then SignF = Negative TempF = (TempC + 5000) * 900 TempF = div32 500 TempF = TempF - 12200 return else SignF = Positive TempF = (TempC + 5000) * 900 TempF = div32 500 TempF = 12200 - TempF return endif endif ' SignF = Positive 'Sign is + ' TempF = ((TempC * 18) / 10) + 3200 'Convert from C to F return
Regards,Code:ReadDS18S20:' Works, mostly.....--Thanks 'Kid' from Forum----------------------- owout Tsensor,1,[$CC, $44] 'Send Start Temperature Conversion command owout Tsensor,1,[$CC, $BE] 'Send Read Temperature command owin Tsensor,0,[STR dq\9] 'Retrieve all 9 bytes of data RawTemp.Byte0 = dq[0] RawTemp.byte1 = dq[1] if RawTemp.8 = 1 then 'Check if temperature is a negative reading SignC = Negative RawTemp.lowbyte = RawTemp.lowbyte ^ 255 'Invert data else SignC = Positive endif dummy = RawTemp.0 'Store the half degree indicator bit TempC = ((RawTemp.lowbyte) >> 1) * 100 'Divide raw data by 2 to give real temperature TempC = TempC + (dummy * 50) 'Add the half degree is present ' if SignC = Negative then 'Only proceed if temperature is negative - doesnt work for F, fine for C ' if TempC => 1770 then ' SignF = Negative ' TempF = (TempC + 5000) * 900 ' TempF = div32 500 ' TempF = TempF - 12200 ' return ' else ' SignF = Positive ' TempF = (TempC + 5000) * 900 ' TempF = div32 500 ' TempF = 12200 - TempF ' return ' endif ' endif SignF = Positive 'Sign is + TempF = ((TempC * 18) / 10) + 3200 'Convert from C to F return
- Albert Einstein
