ds18s20 reads incorectly
Results 1 to 40 of 43
    Your bit-banged read & write routines use a @ NOP for a 1uS delay, but you're running
    at 20MHz so these are only 200nS. You would need 5 x @ NOP for a 1uS delay.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Default Reply
    Thanks For The Math Help
    As For As Speed Goes I Have Treid 4 And 20 Does Not Make A Difference
    Will Work On The Math Issue
    Do You Have The Thermostat Program In Pbp Not Hex
    Wink I do not give the fish any more ...
    Hi, Jcleaver
    The thermostat program was for you to verify what you had to find ... and show you a different Bargraph view.
    NOT to copy / paste it ...
    You can find any parts of it on this forum, The DS18x20 subject has been widely explored during the past months.
    but that need some little efforts ... is it the problem ?
    Unhappy
    Awwwww!!!!!
    This code works great and gives the correct temperature throughout the sensors range in both Fahrenheit and Celsius. The format is like this: TempC = 2250 = 22.50ºC, TempF = 7250 = 72.50ºF.
    ReadDS18S20:
        owout sensor,1,[$CC, $44]                       ' Send Start Temperature Conversion command
        owout sensor,1,[$CC, $BE]                       ' Send Read Temperature command
        owin sensor,0,[STR dq\9]                        ' Retrieve all 9 bytes of data
        RawTemp.Byte0 = dq[0]
        RawTemp.byte1 = dq[1]
        if RawTemp.8 = 1 then                           ' Check if temperature is a negative reading
            SignC = Negative
            RawTemp.lowbyte = RawTemp.lowbyte ^ 255     ' Invert data
            SignC = Positive
        dummy = RawTemp.0                               ' Store the half degree indicator bit
        TempC = ((RawTemp.lowbyte) >> 1) * 100          ' Divide raw data by 2 to give real temperature
        TempC = TempC + (dummy * 50)                    ' Add the half degree is present
        if SignC = Negative then                        ' Only proceed if temperature is negative
            if TempC => 1770 then
                SignF = Negative
                TempF = (TempC + 5000) * 900
                TempF = div32 500
                TempF = TempF - 12200
                SignF = Positive
                TempF = div32 500
                TempF = 12200 - TempF
        SignF = Positive
        TempF = TempC * 18 / 10 + 3200
    May 2008
    Florida
    Jack
    The reason your PBP version did not work was because:
    You attempted to convert C to F using the RAW temp from the DS18S20.
    TEMP = ((TEMP*9/5)+32 )
    Then tried to calculate the temp from the results.
    Lcdout $fe, 1, dec (temp >> 1),".",dec(temp.0 * 5)," degrees C"
    For the fun of it lets plug some numbers in assume 27.5 C is the temp today.
    From the datasheet : The temperature sensor output has 9-bit resolution, which corresponds to 0.5°C steps.
    so 27.5*2 = 55
    Temp = (55*9/5) + 32 = 131
    So Temp now is equal to 131.
    Next we shift right 131>>1 same as temp/2 = 65.5
    Hmmm 65.535 does that number ring a bell?
    Wonder what would happen if you were to shift first then convert C to F like all of the other code posted does?
    temp = (temp>>1*9/5) +32 = (27.5*9/5)+32 = 81.5 F
    Hopefully this explains to you why it works in MikroBasic and not in PBP. The math is not broken, just the order of operation.
    That is why I said check math, simple change would fix it.
    Acetronic: I ask because you posted for jcleaver, would not take without asking first.
    Quote Originally Posted by manwolf View Post
    Nice find. I should've caught that the first time around.
    Sep 2007
    Waco, Texas
    Default Re: ds18s20 reads incorectly
    I am trying to follow your code in an effort to better understand it, but I don't understand
    SignC = Positive
    ReadDS18S20:
            SignC = Negative
            SignC = Positive
                SignF = Negative
                TempF = div32 500
                SignF = Positive
                TempF = div32 500
        SignF = Positive
    It would help if you shared the declarations of the variables used.
    sensor equates to the hardware pin connected to the sensor?
    RawTemp is a word?
    dq is an array of 9?
    dummy is a byte?
    TempC is a byte?
    TempF is a byte?
    I don't get SignC or SignF and how you can equate to 'Positive' or 'Negative', I couldn't find a reference in the PBP manual.
    Explanation would be appreciated.
    "If we knew what we were doing, it wouldn't be called research"
    - Albert Einstein
    Jun 2009
    Sc*nthorpe, UK
    For positive temperatures the output increases from 0000h as the temperature increases from 0 deg C.
    For negative temperatures the output decreases from FFFFh as the temperature falls below -0.5 deg C.
    To check for negative any output bit can be checked for 1, when that bit is outside the temperature range of the sensor. The data sheet says
    The sign bit (S) indicates if the value is positive or negative: for positive numbers S = 0 and for negative numbers S = 1.
    In the program RawTemp.8 is chosen as the sign bit.
  1. DS18B20 VS DS18S20 & multiple
    Last Post: - 7th February 2008, 22:43
  2. Using A Ds18s20 And Servo
    By CrazyCooter in forum mel PIC BASIC Pro
    Last Post: - 12th September 2007, 09:41
  3. DS18S20 displays wrong temperatures
    By Shozo Kanamori in forum mel PIC BASIC Pro
    Last Post: - 6th August 2007, 03:18
  4. DS18s20 - negative teperature
    By Ceug2005 in forum mel PIC BASIC Pro
    Last Post: - 2nd February 2005, 12:40
  5. 16F877, DS18S20 and Serial Comm Problem
    By YellowTang in forum mel PIC BASIC Pro
    Last Post: - 26th April 2004, 10:36
