ds18s20 reads incorectly
Results 1 to 40 of 43
Threaded View
  1. #23
    May 2008
    Florida
    jcleaver
    Here is a couple of files for you to play with.
    pbptc.txt is your program that correctly displays the temp C and changes when the temp changes. You will need to change the LCD port, I use an easypic5 and you are using a different port.
    I also have a program for MikroB attached, again it is for the ep5 board.
    Take a few minutes and look at how the temp is being read in both. Once you figure that out you will see where the problem is.
    BTW the formula is from the DS18S20 datasheet.
    In your Mikro file did you notice that the temp was calculated before it is converted?
    if j2 = $FF then
    tmp_sign = "-" ' temperature sign
    j1= j1 or $FF ' complement of two
    j1= j1 + $01
    tmp_sign = "+"
    end if
    j2 = (j1 and $01) * 5 ' Get decimal value
    j1 = j1 >> 1 ' Get temp value
    j1 = ((j1*9/5)+32) 'Convert C to F
    And in your PBP file nothing is calculated until after the conversion.
    TEMP = ((TEMP*9/5)+32 )
    Lcdout $fe, 1, dec (temp >> 1),".",dec(temp.0 * 5)," degrees C"
    Good Luck!
    Acetronics: May I play around with the thermostat program you posted?
  1. DS18B20 VS DS18S20 & multiple
    Last Post: - 7th February 2008, 22:43
  2. Using A Ds18s20 And Servo
    By CrazyCooter in forum mel PIC BASIC Pro
    Last Post: - 12th September 2007, 09:41
  3. DS18S20 displays wrong temperatures
    By Shozo Kanamori in forum mel PIC BASIC Pro
    Last Post: - 6th August 2007, 03:18
  4. DS18s20 - negative teperature
    By Ceug2005 in forum mel PIC BASIC Pro
    Last Post: - 2nd February 2005, 12:40
  5. 16F877, DS18S20 and Serial Comm Problem
    By YellowTang in forum mel PIC BASIC Pro
    Last Post: - 26th April 2004, 10:36
