ds18s20 reads incorectly
Results 1 to 40 of 43
Threaded View
  1. #13
    Wink
    Why not use PBP's built-in OWIN/OWOUT commands?
    The solution simply is here ...
    MKB reads Byte by Byte and Pbp ... as you want !
    just need to program a correct reading with Pbp !
    Further ... TempF = TempC *9/5 + 32 ...
    Remember PbP works with UNSIGNED INTEGERS ...
    PS: Ski, MKB has a built-in timing adjustment,( you check an option in the project window instead of writing a DEFINE ) and The "conversion complete" polling built-in. That surprised me a bit at first time, not to see it in the source listing ...
  1. DS18B20 VS DS18S20 & multiple
    Last Post: - 7th February 2008, 23:43
  2. Using A Ds18s20 And Servo
    By CrazyCooter in forum mel PIC BASIC Pro
    Last Post: - 12th September 2007, 10:41
  3. DS18S20 displays wrong temperatures
    By Shozo Kanamori in forum mel PIC BASIC Pro
    Last Post: - 6th August 2007, 04:18
  4. DS18s20 - negative teperature
    By Ceug2005 in forum mel PIC BASIC Pro
    Last Post: - 2nd February 2005, 13:40
  5. 16F877, DS18S20 and Serial Comm Problem
    By YellowTang in forum mel PIC BASIC Pro
    Last Post: - 26th April 2004, 11:36
