ds18s20 reads incorectly
Results 1 to 40 of 43
    May 2008
    Florida
    maybe you should check the math.
    With a change to the math the program works correctly. Running on a EasyPIC5 board.
    Sorry I was sleeping that day in class, so I can't explain why PBP and MBasic work differently.
    Wink
    Why not use PBP's built-in OWIN/OWOUT commands?
    The solution simply is here ...
    MKB reads Byte by Byte and Pbp ... as you want !
    just need to program a correct reading with Pbp !
    Further ... TempF = TempC *9/5 + 32 ...
    Remember PbP works with UNSIGNED INTEGERS ...
    PS: Ski, MKB has a built-in timing adjustment,( you check an option in the project window instead of writing a DEFINE ) and The "conversion complete" polling built-in. That surprised me a bit at first time, not to see it in the source listing ...
    Default attempt
    the osc is correct dont know why it did not show caps
    tried going with 4 still read low
    ? what changes in math
    TEMP = ((TEMP*9/5)+32 ) is what i am using
    thanks for the inputs
    have not found any samples using owin with this chip
    Thumbs down
    Did you ever try SEARCH with the 1820 Keyword ???
    Surely NO !!!
    I remember having posted a while ago for the DS1820 ...
    Gives ... 22 Hits !
    Gives ... 22 Hits !
    23 Hits now!
    But, he's also using the DS18S20.
    I know...I know...not a lot of difference between the two that can't be handled by a simple read of the datasheet.
    Quote Originally Posted by jcleaver View Post
    Ok, try this:
    @ DEVICE pic16F877A, HS_OSC
    @ DEVICE pic16F877A, WDT_ON
    @ DEVICE pic16F877A, PWRT_ON
    @ DEVICE pic16F877A, BOD_ON
    @ DEVICE pic16F877A, MCLR_on
    @ DEVICE pic16F877A, LVP_OFF
    @ DEVICE pic16F877A, CPD_OFF
    @ DEVICE pic16F877A, PROTECT_OFF
    define osc 20
    define loader_used 1
    define lcd_dreg portd
    define lcd_dbit 4
    define lcd_rsreg portd
    define lcd_rsbit 2
    define lcd_ereg portd
    define lcd_ebit 3
    define lcd_lines 2
    define lcd_bits 4
    define lcd_commandus 2000
    define lcd_dataus 50
    command var byte:i var byte:temp var word:dq var porta.5:dq_dir var trisa.5
    adcon1=255:porta=255:portb=0:trisa=255:trisb=0:cmcon=7
    Lcdout $fe,1,"Temp in degrees C"
    mainloop:	Gosub init1820:command=$cc:Gosub write1820:command=$44
    Gosub write1820:Pause 2000:Gosub init1820:command=$cc:Gosub write1820
    Pause 2000:command=$be:Gosub write1820:Gosub read1820:TEMP=((TEMP*9/5)+32)
    Lcdout $fe,1,dec(temp>>1),".",dec(temp.0*5)," degrees C":Goto mainloop
    init1820:	Low DQ:Pauseus 500:DQ_DIR=1:Pauseus 100
    If DQ=1 Then Lcdout $fe,1,"DS1820 not present":Pause 500:Goto mainloop
    Pauseus 400:Return
    write1820:	For i=0 to 7:low dq
    If command.0[temp] = 0 Then
    	Pauseus 60:DQ_DIR = 1
    Else
    	@ nop
    	DQ_DIR = 1:Pauseus 60
    Endif
    Next i:Return
    read1820:	For i=0 to 15:low dq
    		@ nop
    		dq_dir=1:temp.0[i]=1:if dq=0 then temp.0[i]=0
    		pauseus60:next i:return
    Default Update 2
    Tried This And Get Better Reading Only 6 Deg Low
    However It Does Not Respond To Any Temperature Changes
    Ok, what DOES it put out for a temperature?
    What happens if you heat it up, read the temperature, shut it off, put it in the freezer for a few minutes, take it out, power it up and read the temp right away?
    Question Answer
    Read 65.xxxx
    Does Not Update Hold Sensor And Nothing Changes
    Reloaded Several Programs And They Work However Still Get Low Tmp Reading
    Dont Think Its A Hardware Problem Because It Works Perfectly In Mikroe
    Guess I Could That But Have Better Luck With Pbp As For As Adding My Stuff
  1. DS18B20 VS DS18S20 & multiple
    Last Post: - 7th February 2008, 23:43
  2. Using A Ds18s20 And Servo
    By CrazyCooter in forum mel PIC BASIC Pro
    Last Post: - 12th September 2007, 10:41
  3. DS18S20 displays wrong temperatures
    By Shozo Kanamori in forum mel PIC BASIC Pro
    Last Post: - 6th August 2007, 04:18
  4. DS18s20 - negative teperature
    By Ceug2005 in forum mel PIC BASIC Pro
    Last Post: - 2nd February 2005, 13:40
  5. 16F877, DS18S20 and Serial Comm Problem
    By YellowTang in forum mel PIC BASIC Pro
    Last Post: - 26th April 2004, 11:36
