ds18s20 reads incorectly
Results 1 to 40 of 43
    Sep 2007
    Waco, Texas
    Default Re: ds18s20 reads incorectly
    I am trying to follow your code in an effort to better understand it, but I don't understand
    SignC = Positive
    ReadDS18S20:
        owout sensor,1,[$CC, $44]                       ' Send Start Temperature Conversion command
        owout sensor,1,[$CC, $BE]                       ' Send Read Temperature command
        owin sensor,0,[STR dq\9]                        ' Retrieve all 9 bytes of data
        RawTemp.Byte0 = dq[0]
        RawTemp.byte1 = dq[1]
        if RawTemp.8 = 1 then                           ' Check if temperature is a negative reading
            SignC = Negative
            RawTemp.lowbyte = RawTemp.lowbyte ^ 255     ' Invert data
            SignC = Positive
        dummy = RawTemp.0                               ' Store the half degree indicator bit
        TempC = ((RawTemp.lowbyte) >> 1) * 100          ' Divide raw data by 2 to give real temperature
        TempC = TempC + (dummy * 50)                    ' Add the half degree is present
        if SignC = Negative then                        ' Only proceed if temperature is negative
            if TempC => 1770 then
                SignF = Negative
                TempF = (TempC + 5000) * 900
                TempF = div32 500
                TempF = TempF - 12200
                SignF = Positive
                TempF = div32 500
                TempF = 12200 - TempF
        SignF = Positive
        TempF = TempC * 18 / 10 + 3200
    It would help if you shared the declarations of the variables used.
    sensor equates to the hardware pin connected to the sensor?
    RawTemp is a word?
    dq is an array of 9?
    dummy is a byte?
    TempC is a byte?
    TempF is a byte?
    I don't get SignC or SignF and how you can equate to 'Positive' or 'Negative', I couldn't find a reference in the PBP manual.
    Explanation would be appreciated.
    "If we knew what we were doing, it wouldn't be called research"
    - Albert Einstein
    Jun 2009
    Sc*nthorpe, UK
    For positive temperatures the output increases from 0000h as the temperature increases from 0 deg C.
    For negative temperatures the output decreases from FFFFh as the temperature falls below -0.5 deg C.
    To check for negative any output bit can be checked for 1, when that bit is outside the temperature range of the sensor. The data sheet says
    The sign bit (S) indicates if the value is positive or negative: for positive numbers S = 0 and for negative numbers S = 1.
    In the program RawTemp.8 is chosen as the sign bit.
    Sep 2007
    Waco, Texas
    Thanks EarlyBird2, I did figure that part out. In the code that the 'Kid' supplied, I could not get it to work until I remarked the SignC=Negative portion.
    The code below works, but I have not tried for negative numbers yet..... Could you explain why?
    Thanks and Regards,
    ReadDS18S20:' Works, mostly.....------------------------------------------------
                      owout Tsensor,1,[$CC, $44]                                    'Send Start Temperature Conversion command
                      owout Tsensor,1,[$CC, $BE]                                    'Send Read Temperature command
                      owin Tsensor,0,[STR dq\9]                                     'Retrieve all 9 bytes of data
                      if RawTemp.8 = 1 then                                         'Check if temperature is a negative reading
                         SignC = Negative
                         RawTemp.lowbyte = RawTemp.lowbyte ^ 255                    'Invert data
                         SignC = Positive
                      dummy = RawTemp.0                                             'Store the half degree indicator bit
                      TempC = ((RawTemp.lowbyte) >> 1) * 100                        'Divide raw data by 2 to give real temperature
                      TempC = TempC + (dummy * 50)                                  'Add the half degree is present
    '                 if SignC = Negative then                                      'Only proceed if temperature is negative - doesnt work for F, fine for C
    '                    if TempC => 1770 then
    '                       SignF = Negative
    '                       TempF = (TempC + 5000) * 900
    '                       TempF = div32 500
    '                       TempF = TempF - 12200
    '                    return
    '                  else
    '                      SignF = Positive
    '                      TempF = div32 500
    '                      TempF = 12200 - TempF
    '                      return
    '                   endif
    '                 endif
                      SignF = Positive                                              'Sign is +
                      TempF = ((TempC * 18) / 10) + 3200                            'Convert from C to F
    - Albert Einstein
    Jun 2009
    Sc*nthorpe, UK
    Negative and Positive are declared variables or constants. In your code should be
    Negative CON 1
    Positive CON 0
    Does this help?
    Could be SYMBOL or ALIAS of course.
    Sep 2007
    Waco, Texas
    EarlyBird2-
    Thanks! I just tried it (I did NOT have them as CONstants), compiles fine but still gives me 0.00F.
    Code is below for clarification.
        Positive    con 0                                                           'Bit used for + in the DS18S20
        Negative    con 1                                                           'Bit used for - in the DS18S20
        rawtemp         var word                                                    'Raw temp var
        tempC           var word                                                    'Temp var for degrees C
        tempF           var word                                                    'Temp var for degrees F
        dq              var byte[9]                                                 'String of data from DS18S20
        SignC           var bit                                                     'Bit for + or - for degrees C
        SignF           var bit                                                     'Bit for + or - for degrees F
        dummy           var bit                                                     'Temp var
    ReadDS18S20:' Works, mostly.....--Thanks 'Kid' from Forum-----------------------
                         SignC = Negative
                         SignC = Positive
                           SignF = Negative
                           TempF = div32 500
                          SignF = Positive
                          TempF = div32 500
    '                  SignF = Positive                                              'Sign is +
    '                  TempF = ((TempC * 18) / 10) + 3200                            'Convert from C to F
    This what I have that does work, just not for negatives.....
                         SignC = Negative
                         SignC = Positive
    '                       SignF = Negative
    '                       TempF = div32 500
    '                    return
    '                  else
    '                      SignF = Positive
    '                      TempF = div32 500
    '                      return
    '                   endif
    '                 endif
    - Albert Einstein
    Jun 2009
    Sc*nthorpe, UK
    these two lines are commented out?
    so I guess you will get 0 deg F
    Sep 2007
    Waco, Texas
    Steve-
    Dunno what I had thought I was looking at, but when I un-commented those other lines, I now get correct readings!
    This is now what seems to be working:
    BTW, going to be in your neck of the woods this Wednesday, 2 days in London, then take a boat out from South Hampton on a cruise through the Baltics.
    Thanks for pushing me in the right track!
    ReadDS18S20:' Works, Thanks 'Kid' and Steve from the UK....from Forum-----------
                         SignC = Negative
                         SignC = Positive
                           SignF = Negative
                           TempF = div32 500
                          SignF = Positive
                          TempF = div32 500
    - Albert Einstein
  1. DS18B20 VS DS18S20 & multiple
    Last Post: - 7th February 2008, 22:43
  2. Using A Ds18s20 And Servo
    By CrazyCooter in forum mel PIC BASIC Pro
    Last Post: - 12th September 2007, 09:41
  3. DS18S20 displays wrong temperatures
    By Shozo Kanamori in forum mel PIC BASIC Pro
    Last Post: - 6th August 2007, 03:18
  4. DS18s20 - negative teperature
    By Ceug2005 in forum mel PIC BASIC Pro
    Last Post: - 2nd February 2005, 12:40
  5. 16F877, DS18S20 and Serial Comm Problem
    By YellowTang in forum mel PIC BASIC Pro
    Last Post: - 26th April 2004, 10:36
