programmer compatability, 16f88
Results 1 to 11 of 11
    Apr 2008
    Default programmer compatability, 16f88
    Could somebody please give me an idea as to why my programmer won't program 16f88 pic's.
    I'm trying to load a simple program
     	CMCON = 7		' Disable Comparators
    	ansel = 0
    	start:
    	portb.0 = 1
    	portb.0 = 0
    	goto start
    through my pic programer and checker board which I have programmed 16f84 and 16f628's many times before and still do, Ive included a picture of the schematic. I am using icprog with direct I/O invert mclear and invert vcc checked.cheers in advanced
    Sep 2006
    Mexico
    Hello, Is software problem or hardware proble?
    If its in software, you need to use TRIS command to select input or output on a pin and config directives like internal or external osc, mclr, etc.
    However, if you cant read/write your pic, probably it is not supported by your programmer.
    Apr 2008
    i cannot get the program on to the pic, I just want to know what is the electrical programming difference between the 16f628 , 84 to the 88??? I wouldnt think there would be any?
    Oct 2007
    The Netherlands
    Does your programmer support this PIC?
    Quote Originally Posted by cphillips82 View Post
    www.microchip.com has all the programming specifications for the various PICs in various PDFs. And yes, there is a difference between the programming methods used from the 16f628 (old school) and the 16f88 (newer-ish school). Just because a programmer supports the 16f628/16f84 (old school), doesn't mean it supports the 16f88 (much newer in comparison).
    From the date on those pictures, it looks like 2001. I'm fairly sure that the 16F88 came out after much later.
    Apr 2008
    yes, this was made well before the 16f88 was out and even before the 16f628 yet that still works. seems a shame. I LOVE THIS BOARD!!
    In most cases, it's not the programmer hardware that makes or breaks it for a specific PIC, it's the firmware/software that's driving it.
    Mar 2006
    Hyderabad (India)
    Are you not expected to indicate the chip and full configuration data while writing programs in BASIC?
    Sarma
    If you're using PORTB.0=1 or PORTB.0=0 you'll want to include TRISB.0=0 first to make the
    pin an output, or change to HIGH 0 / LOW 0. Port pins are set as inputs by default on
    power-up.
    HIGH & LOW commands will automatically handle setting TRIS for you, where PORTB.0=? will
    not.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
  1. Melabs U2 Programmer Command Line Options
    By Robert Wells in forum General
    Last Post: - 3rd July 2009, 03:11
  2. problems with USB programmer
    By malc-c in forum General
    Last Post: - 10th May 2007, 21:14
  3. USB programmer problems
    By uiucee2003 in forum USB
    Last Post: - 16th August 2006, 00:47
  4. Melabs USB Programmer
    By tmurph in forum General
    Last Post: - 25th December 2005, 04:25
  5. General Programmer Questions
    By mslaney in forum General
    Last Post: - 17th December 2004, 19:16
