16f84a running interrupt PICBASIC code
Results 1 to 19 of 19
    Quote Originally Posted by divaker View Post
    When it is simed on MPLAB, it is quite OK. But when it is run on the chip, it does not work.
    And you're sure the PIC is running in the first place?
    How does the 'blinky LED' program run?
    Jul 2008
    Default Reply - 16f84a running interrupt PICBASIC code 16f84a
    Dear skimask,
    Yes, the "blinky and the button" worked as required right on the PIC16f84.
    Similarly the interrupt driven routine also worked well separately on the PIC
    But when these two are put together on the PIC it odes not work.
    Though the MPLAB simulates it well enough and comes thru'.
    Divaker
    Looks to me like you have to do some big time reorganization of your program...You've got it jumping all over everything...
    Here's how I normally do things...might not be optimal, but it keeps me out of trouble:
    Defines
    Variable declarations
    ASsembly macros
    Skip over Int Handler/Subroutines
    On Interrupt statement
    Int Handler routine
    Subroutines
    PIC, PIC pins and other hardware Setup/Initialization
    Main body
    And besides all that, I don't see where you clear the TMR0 overflow flag like it says you have to do in the datasheet. I see you enable the TMR0 interrupt a couple of times which has the side effect of clearing the flag...but probably not at the right time.
    Jul 2008
    Dear skimask,
    Thanks for your time and the suggestions.
    Let me reorganize and see. Also I will clear the TMR0 approp.
    However, I wonder how come the interrupt routines without the blink button works absolutely alright on the PIC.
    And when I removed the whole button routines and rewrote the code to accept the variable 'spacing' from PORTA through a DIP switch, the code worked without hitch on the PIC.
    Divaer
    Divaer
    Probably because the blink button code had PAUSEs in it. The 'On Interrupt' doesn't fire if it's blocked by a PAUSE or any other statement that needs to complete before the next statement can execute. More details about 'On Interrupt' in the manual.
    I tried it @ 20mhz with code below, I have no provision to increment the timer right now but it does change the outputs on RB0 & RB1 when you switch RB7
    @MyConfig = _HS_OSC & _WDT_OFF & _PWRTE_ON
    @ __config  MyConfig
    DEFINE OSC 20
    Symbol OUT_PIN     = PORTB.0     'Output to solenoid RB0
    Symbol LED         = PORTB.1     'Control button to RB1
    Symbol CNTL_BUTTON = PORTB.7     'Control button to RB7
    spacing var byte
    temp    var byte
    TRISA=$FF
    TRISB = $FC  ' RB0 and RB1 outputs, others input
    portB = 0
    '* * * * * * * Set initial value to variables * * * * * * * * * * *
    spacing = 15
    LED = 0
    temp=1
    ' Program starts with gosub to Wait_Button
    gosub wait_button
    LED = 1            ' on return turn on LED
    pause 2000         ' Wait for two seconds
    if CNTL_BUTTON = 1 then spacing = 30
    goto direct        'If button is released before 2 secs
                       'code goes directly into the default spacing
    temp=0
    gosub wait_button 'If button is pressed more than 2 secs,
                      'it gets caught here and waits for release
    LED = 0
    pause 1000 ' Wait for 100 ms
    repeata:
        spacing = spacing +5 'Increase the spacing count by 2 every time
        toggle LED: pause 1000: toggle LED
    	if spacing = 45 then spacing = 20 'Till it reaches maximum and reset to minimum
    	temp=1
    	gosub wait_button 'Access the push button state and repeat if short press
        pause 2000 ' Delay for 2 seconds
        if CNTL_BUTTON = 1 then goto repeata
    LED = 1
    OUT_PIN = 0
    'Calculate the value to be loaded into TMR0 for counting at RA4 connected to the encoder output
    'Use a multiplier to convert the spacing in cm to number of pulses to count
    'Say if the distance measuring wheel's dia is 40 cm then its circumference = 3.14*40 appr    = 125 cm
    'For one revolution ie 125 cm distance traveled = 500 pulse outputs of encoder
    'Correspondingly 500/125 = 4 pulses/cm distance, therefore set the count as 255 - (spacing * 4)
    direct:
    spacing =  255 - (spacing * 4)
    OPTION_REG = %00110000 ' TMR0, counter set option_reg<5> clear for timer
                           ' Option_Reg<4> set for falling edge clear for
                           ' rising edge detection.
    ON INTERRUPT GOTO ISR ' Interrupt service routine
    TMR0 = spacing
    OUT_PIN = 0
    INTCON = %10100000 ' Enable TMR0 overflow interrupt
    'This is the interrupt service routine, ISR. The program jumps here whenever TMR0 overflow occurs
    DISABLE 'Disable interrupts
    ISR: 'Entry point of the ISR
    OUT_PIN = 1
    TMR0 = spacing
    INTCON.2 = 0 ' Reset timer interrupt flag
    RESUME ' Resume main program
    ENABLE ' Enable interrupts
    wait_button:
    if CNTL_BUTTON && 1 =temp then wait_button
    Jul 2008
    Thanks for your effort Joe.
    But do you mean that the code is really working for you on the chip as expected?
    Then what could be the problem with mine?
    Is it something to do with my power supply?
    As soon as I make the first press of the button (RB7), the chip seems to reset. (Of course the WDT was off!)
    Dear skimask,
    But I dont need the interrupts fire when I am setting the variable 'spacing' through the button presses (short and long involving Pauses!). Only after that button part is over, (after the label 'direct') the inerrupt needs to work.
    Divaker
  1. Code works on 16F84A but not on 16F88?
    By pharaohamps in forum mel PIC BASIC Pro
    Last Post: - 6th November 2009, 18:29
  2. Help with Analog Interrupt
    By brid0030 in forum mel PIC BASIC Pro
    Last Post: - 13th February 2008, 18:14
  3. 16F876A CCP1 Capture/Interrupt Question
    By TDonBass in forum mel PIC BASIC Pro
    Last Post: - 17th January 2008, 03:25
    Last Post: - 30th May 2006, 22:50
  5. NEWBIE: Some basic questions using interrupts
    By JackPollack in forum mel PIC BASIC Pro
    Last Post: - 8th March 2006, 02:59
