I routinely use the PIC 18LF4620 at 3.7 down to 2.5 volts. I run at 4 MHz and the config data I load into the Melabs USB serial programmer is:-
Do NOT enable LVP which is the short life option - you will go mad and die young trying to find intermittent programming problems.Code:'************* Config Register setup for USB programmer **************** ' OSC = HS, FSCM = En, IESO = En, PwrupTmr = En, BrownOut = Dis ' BOR Volts = 2, WDT = Off, WDTPS = 1:512, CCP2 mux = RB3, ' PortB rst = Digital, LPT1Osc = Low, MCLR = Reset, LVP = Dis ' Enhanced CPU = Dis, All memory = Not Protected ' Note re power consumption. PBP assumes the WDTPS is set to 512. ' SLEEP draws 2.5 uA in this system. Each time sleep times out there ' is a current pulse for 2.5 mSecs at 600 uA. Setting WDTPS = 1024 extends ' the SLEEP internal period by 2 and so the average power drops BUT ' PBP will get the sleep times wrong by the factor of chosen WDTPS:512 '************************************************************
Even when the WDT is disabled, the WDT post scaler is active and to get the sleep times right you must set the WDTPS to 512.
Enabling the WDT adds 2 uA to the sleep current.
Enabling the BOD also adds about 2 uA to the sleep current.
HTH
BrianT
