Instant Interrupt and USART
Results 1 to 6 of 6
    Jan 2007
    Brazil
    Default Instant Interrupt and USART
    Hello.. again...
    Well, I'm trying to use Timer1 and USART interrupts using Darrel Ins. Interrupts.
    If I disable RX and TX interrupts, Timer1 works really fine. However, if all of them are enable, rx-tx works (microcode serial comm.) but not timer1..
    Any ideas?
    Thank again!
    INT_LIST macro ;IntSource, Label,    Type, ResetFlag?
        INT_Handler TMR1_INT, _Timer1,   PBP, yes
        INT_Handler RX_INT,   _GetChar,  PBP, yes
        INT_Handler TX_INT,   _SendChar, PBP, yes
    @    INT_ENABLE  TMR1_INT   ; TMR1
    @    INT_ENABLE  RX_INT     ;- enable the interrupt
    @    INT_ENABLE  TX_INT     ;- enable the interrupt
    Timer1:
        TMR1L = load.lowbyte
        TMR1H = load.highbyte
        FLAG = 1
    @ INT_RETURN
    GetChar:
          HSERIN 1, go, [cod]
          received = 1
          goto theend
    go: received = 0
    theend:
    @ INT_RETURN
    SendChar:
          if received= 1 then hserout [cod]
          received= 0
    @ INT_RETURN
    Sylvio,
    TX_INT works a little different than the other interrupts.
    It's interrupt flag is set when the TXREG register is empty, which means it's almost always =1. So you always end up back in the interrupt handler if TX_INT is ENABLED. Nothing else will be able to do anything because it's continuously entering and exiting the interrupts.
    When you place a byte in TXREG (via HSEROUT), it gets transferred to the TSR register, and the flag gets set again even though the USART is currently transmitting the byte. The TRMT bit will =1 While the USART is transmitting.
    If USART is still transmitting the byte in TSR when you place another byte in TXREG, the TXIF flag will finally be cleared and you can successfully leave the interrupt handler. But as soon as the byte in TSR is gone, the flag gets set again, and away you go back to the handler.
    Essentially what this all does is to allow you to have data ready and waiting to be sent, and let the USART tell you when it's OK to send the next byte.
    If you don't have any data waiting, it's a constant conversation between the program and the USART.
    USART: Hey, it's ok to send.
    PROGRAM: I have nothing to send.
    What needs to be done here is to control when the TX_INT is ENABLED. If there is data waiting to be sent then ENABLE TX_INT. When it's ok to send, the USART will fire the TX interrupt and you can put 1 byte into TXREG. If there is still more data to be sent, exit the handler and it will interrupt again when it's ready to send the next byte.
    If there's no more data to send, DISABLE TX_INT to keep it from continuously interrupting.
    Also, when you're only working with 1 byte at a time, there's no need for Timeouts in the HSERIN statement. When you get an RX interrupt, you are guaranteed to have at least 1 byte in the USART buffer.
    For your previous LoopBack example it could look like this,...
    @    INT_ENABLE  RX_INT     ;- enable the RX interrupt
    Timer1:
        FLAG = 1
    @ INT_RETURN
    GetChar:
        HSERIN [cod]
    @   INT_ENABLE  TX_INT     ;- enable the TX interrupt
    @ INT_RETURN
    SendChar:
        hserout [cod]
    @   INT_DISABLE  TX_INT    ;- disable the TX interrupt
    @ INT_RETURN
    Jan 2007
    Brazil
    Darrel, I did think that it was interrupting all the time but i was not sure. Thanks for the help! I got it working now!
    By the way, i'm still laughing about the conversation......
    Thanks!
    Sylvio,
    Jan 2007
    Brazil
    Thumbs down
    Hello again..
    As I posted, it worked well when using a single byte (cod). But, I can´t get it working when using array (cod[4]).
    COD    VAR   BYTE[4]
    HSERIN [STR COD\4]
    or
    HSERIN [STR COD\4\"~"]
    HSEROUT [STR COD\4]
    When using serial comm. as an echo, I get 'strange' number, but never a complete byte.
    I've looked for this hserin format all over the forum but none of the solutions worked yet...
    Any ideas?
    Thanks again!
    Sylvio,
    Quote Originally Posted by sirvo View Post
    Thanks again!
    What happens if you use 4 HSERIN's back-to-back?
    Jan 2007
    Brazil
    Well, it works!
    Danke schön!
    Thanks skimask!
    Sylvio,
  1. Instant Interrupts - Revisited
    Last Post: - 17th February 2016, 23:14
  2. Usart with Darrel Instant Interrupt
    By Pedro Pinto in forum mel PIC BASIC Pro
    Last Post: - 17th February 2008, 01:09
  3. Help with Analog Interrupt
    By brid0030 in forum mel PIC BASIC Pro
    Last Post: - 13th February 2008, 19:14
  4. Replies: 1
    Last Post: - 3rd November 2006, 00:24
