Another Serial data using Manchester question
Results 1 to 9 of 9
    "In this case, you're only sending a handful of codes back and forth, not random binary data that has to be coded and decoded 'on-the-fly'.
    So, why not 'hardcode' each of those 'bytes' to their equivalent manchester values?"
    0 = 01010101
    1 = 01010110
    Would I just send and receive this as a BYTE or Word?
    Quote Originally Posted by tazntex View Post
    0 = 01010101
    1 = 01010110
    Well, since there's only 8 bits, I'd say a BYTE, 'cause there's only 8 bits.
    If there was 16 bits, I'd say a WORD, or maybe 2 bytes...
    Thanks again Skimask, I have it all working now after using the hardcode you recommended. I never could get the encoder decoder section to work. Everything seem good now, been on it all weekend. I found a couple of errors after rereading the program over and over. Now I have a new question, how would I keep lets say portb.1 high on the receiver as long as I was pressing the button on the transmitter but portb.1 to go low if I release the button?
  1. Using Nokia LCD
    Last Post: - 3rd May 2018, 05:47
  2. Nokia 3310 display text
    Last Post: - 26th August 2007, 04:39
  3. Big characters on HD44780 4x20
    Last Post: - 7th January 2007, 03:21
  4. LCD + bar graph
    Last Post: - 5th October 2005, 15:50
  5. Sinus calculating !
    Last Post: - 29th November 2004, 00:56
