Another Serial data using Manchester question
Results 1 to 9 of 9
    Default Another Serial data using Manchester question
    I have been reading many post on manchester encoding/decoding and have been trying to get this code to work. Before I was just sending the state of portb out and receiving it in and it was working, but would miss bits. So after reading about Melanie's, Bruce and Ioannis (I hope thats the correct spelling), post I tried Ioannis version. It seems to be clearer than most, but now nothing works. Any suggestions?
    Here is the code I've been experimenting with:
    Serial Transmitter
    @ DEVICE PIC16F628a,XT_OSC
    @ DEVICE pic16F628a, WDT_OFF
    ' Watchdog Timer
    @ DEVICE pic16F628a, PWRT_ON
    ' Power-On Timer
    @ DEVICE pic16F628a, MCLR_ON
    ' Master Clear Options (Internal)
    @ DEVICE pic16F628a, BOD_ON
    ' Brown-Out Detect
    @ DEVICE pic16F628a, LVP_OFF
    ' Low-Voltage Programming
    @ DEVICE pic16F628a, CPD_OFF
    ' Data Memory Code Protect
    ' Set to CPD_OFF for Development Copy
    ' Set to CPD_ON for Release Copy
    @ DEVICE pic16F628a, PROTECT_OFF
    define osc 4
    include "bs2defs.bas"
    CMCON=%00000111
    i var byte
    encoded var word
    dgood var porta.2
    serpin var porta.3
    nokey con %11111111
    synch con 254
    keyin var portb
    mydata var byte
    trisb = %11111111
    trisa = %00010111
    ro VAR PORTB.0
    ri VAR PORTB.1
    bkl VAR PORTB.2
    es VAR PORTB.3
    rb VAR PORTB.4
    lb VAR PORTB.5
    bl VAR PORTB.6
    na VAR PORTB.7
    findkey:
    if rn = 0 then sw1
    if lb = 0 then sw2
    if ri = 0 then sw3
    if ro = 0 then sw4
    if es = 0 then sw0
    if bl = 0 then sw5
    if bkl = 0 then sw6
    goto findkey
    sw0:
    mydata = %0100
    goto dout
    sw1:
    mydata = %0101
    goto dout
    sw2:
    mydata = %0110
    goto dout
    sw3:
    mydata = %0010
    goto dout
    sw4:
    mydata = %0001
    goto dout
    sw5:
    mydata = %0111
    goto dout
    sw6:
    mydata = %0011
    goto dout
    dout:
    low dgood
    For i=0 TO 7
    IF mydata.0[i]=0 Then
    encoded.0[i*2]=0
    encoded.0[i*2+1]=1
    Else
    encoded.0[i*2]=1
    encoded.0[i*2+1]=0
    EndIF
    Next i
    serout serpin,N2400,[$55,$55,$55,$55,$55,synch,encoded]
    if keyin = nokey then x2
    goto findkey
    x2:
    high dgood
    mydata = %00000000
    goto findkey
    Serial Receiver
    INCLUDE "bs2defs.bas"
    ' Watchdog Timer
    ' Power-On Timer
    ' Brown-Out Detect
    mydata VAR byte
    encoded var word
    serpin VAR porta.1 'serial input pin
    PORTA = 0
    PORTB = 0
    trisa = %00000010
    trisb = %10000000
    CMCON=%00000111
    i var byte
    PAUSE 50 ' settle time
    loop:
    gosub loop1
    branch mydata, [rly1,rly2,rly3,rly4,rly5,rly6,rly7]
    GOTO loop
    rly1:
    toggle 0
    pause 250
    goto loop
    rly2:
    HIGH 1
    pause 50
    if mydata <> %0101 then low 1
    GOTO loop
    rly3:
    HIGH 2
    pause 50
    if mydata <> %0110 then low 2
    GOTO loop
    rly4:
    HIGH 3
    pause 50
    if mydata <> %0010 then low 3
    GOTO loop
    rly5:
    HIGH 4
    pause 50
    if mydata <> %0001 then low 4
    GOTO loop
    rly6:
    toggle 5
    pause 250
    GOTO loop
    rly7:
    TOGGLE 6
    PAUSE 250
    GOTO loop
    loop1:
    SERIN serpin,N2400,[254],encoded
    For i=0 TO 7
    IF encoded.0[i*2]=0 Then
    IF encoded.0[i*2+1]=1 Then
    mydata.0[i]=0
    EndIF
    Else
    mydata.0[i]=1
    EndIF
    Next
    Thank you all for you help.
    Look at your transmitter program...Follow the code flow very carefully!!!
    You'll find your error...It's in there...
    Specifically, does the number of GOSUB's equal the number of RETURN's?
    Thanks SKIMASK, I believe you were referring to the RETURN in this section:
    dout:
    low dgood
    For i=0 TO 7
    encoded.0[i*2]=0
    encoded.0[i*2+1]=1
    Else
    encoded.0[i*2]=1
    encoded.0[i*2+1]=0
    EndIF
    Next i
    Return ' I took this out
    goto findkey
    Ive recompiled it, still doesn't work, I check the serial out pin with Oscope and it shows a datastream, Out of curiosity, I have a whole sleeve of the processors so I replaced both but still no luck
    Quote Originally Posted by tazntex View Post
    Yes
    And you HAVE tried this without the RF link? Yes? Without the manchester encoding?
    'Serial Transmitter
    @ DEVICE pic16F628a, WDT_OFF ' Watchdog Timer
    @ DEVICE pic16F628a, PWRT_ON ' Power-On Timer
    @ DEVICE pic16F628a, MCLR_ON ' Master Clear Options (Internal)
    @ DEVICE pic16F628a, BOD_ON ' Brown-Out Detect
    @ DEVICE pic16F628a, LVP_OFF ' Low-Voltage Programming
    @ DEVICE pic16F628a, CPD_OFF ' Data Memory Code Protect
    define osc 4  <-Define's won't work unless they're in CAPS (RTFM)
    CMCON=7 : i var byte : encoded var word : dgood var porta.2 : serpin var porta.3
    nokey con $ff : synch con 254 : keyin var portb : mydata var byte : trisb = $ff : trisa = $17
    ro VAR PORTB.0 : ri VAR PORTB.1 : bkl VAR PORTB.2 : es VAR PORTB.3 : rb VAR PORTB.4
    lb VAR PORTB.5 : bl VAR PORTB.6 : na VAR PORTB.7
    findkey: if rn = 0 then mydata=5 : goto dout
    if lb = 0 then mydata=6 : goto dout
    if ri = 0 then mydata=2 : goto dout
    if ro = 0 then mydata=1 : goto dout
    if es = 0 then mydata=4 : goto dout
    if bl = 0 then mydata=7 : goto dout
    if bkl = 0 then mydata=3 : goto dout
    goto findkey
    dout: dgood=0 : pause 100 : For i=0 TO 7
    IF mydata.0[i] = 0 Then
    encoded.0[i*2]=0 : encoded.0[i*2+1]=1
    Else
    encoded.0[i*2]=1 : encoded.0[i*2+1]=0
    EndIF
    Next i : serout serpin,N2400,[$55,$55,$55,$55,$55,synch,encoded]
    goto findkey
    x2: dgood=1 : mydata=0 : serout serpin,N2400,[$55,$55,$55,$55,$55,synch,mydata]
    goto findkey
    'Serial Receiver
    mydata var byte : encoded var word : serpin var porta.1 : porta=0 : portb=0 : trisa=2
    trisb=$80 : CMCON=7 : i var byte : PAUSE 50
    loop: gosub loop1
    select case mydata
    case 0
     toggle 0 : pause 250
    case 1
     HIGH 1 : pause 50 : if mydata <> %0101 then low 1
    case 2
     HIGH 2 : pause 50 : if mydata <> %0110 then low 2
    case 3
     HIGH 3 : pause 50 : if mydata <> %0010 then low 3
    case 4
     HIGH 4 : pause 50 : if mydata <> %0001 then low 4
    case 5
     toggle 5 : pause 250
    case 6
     toggle 6 : pause 250
    end select
    goto loop
    loop1: SERIN serpin,N2400,[254],encoded : For i=0 TO 7
    IF encoded.0[i*2+1]=1 Then mydata.0[i]=0
    Else
    mydata.0[i]=1
    EndIF
    Next i : Return
    Thanks again for your advice, I had tried it before with direct cable connection when I began tinkering with this and it did work. But sometimes I would get the relays to turn on and off kind of a quick chattering. I have the flyback protection on my relays to help prevent that. Then I notice that after reading other peoples questions about using rf links and having similar problems that Manchester encoding/decoding seemed to resolve this issue. This is why I am trying to experiment with this. Perhaps I may learn from this experience. I am really interested in become proficient with PicBasic Pro, and Bruce has help me alot over the last couple of years. I hope he gets time to publish a book that has clearer examples than the PBP manual has. People like you, Bruce, Melanie and Ioannis are a real asset to this forum. Thanks again for all your help.
    One other little 'note to self' for this particular program...
    In this case, you're only sending a handful of codes back and forth, not random binary data that has to be coded and decoded 'on-the-fly'.
    So, why not 'hardcode' each of those 'bytes' to their equivalent manchester values?
    0 = 01010101
    1 = 01010110
    and so on.....
    At least that way, you'll take out any chance that the 'manchester routine' is causing the problem.
  1. Using Nokia LCD
    Last Post: - 3rd May 2018, 05:47
  2. Nokia 3310 display text
    Last Post: - 26th August 2007, 04:39
  3. Big characters on HD44780 4x20
    Last Post: - 7th January 2007, 03:21
  4. LCD + bar graph
    Last Post: - 5th October 2005, 15:50
  5. Sinus calculating !
    Last Post: - 29th November 2004, 00:56
