Vinculum VNC1L Vdrive2 module problems
Results 1 to 10 of 10
    Jul 2008
    I'm using Ascii values in ECS mode (it's working, as I said) and I'm have to use Binary values to set from ECS mode in SCS mode, and then I have to send commands in SCS mode. I can't post the code because the project is too big (C/C++ project-I'm working with an Embedded 386SX CPU ISA Half Size SBC Series).I was thinking that someone has encountered a bug about SCS mode...
    Good luck, I can not help with C, most of us here use PIC BASIC. Guess that is why this forum is named MELabs PICBASIC Forums .
    I will suggest contacting FTDI, their support is pretty good.
    Jul 2008
    Ok..thanks! (I've write here because it's the only forum where someone writes about Vdrive2)
    Quote Originally Posted by the_virus View Post
    That is interesting. I thought they were more popular.
    I have a project coming up were I will be using a VDIP1. When I get started on it I will give shorts a try (still do not see the advantage) and post what happens here.
  1. VDIP1 (Vinculum - FTDI) problems
    Last Post: - 20th August 2013, 14:51
  2. How to drive the Vinculum VDIP1 in UART mode
    By BrianT in forum Code Examples
    Last Post: - 23rd May 2013, 13:34
  3. Vinculum Vdrive2
    By enigma in forum USB
    Last Post: - 8th May 2012, 02:51
  4. Version Control
    Last Post: - 16th October 2011, 18:12
  5. Replies: 1
    Last Post: - 27th July 2008, 07:14
