18F252 config
Results 1 to 6 of 6
Thread: 18F252 config
Threaded View
    Sep 2006
    Venezuela - Caracas
    Default 18F252 config
    i need change my config because 18F2520 finish in my city....then i but 18F252 and
    i have problem with config
    code/pic work with 8 mhz internal oscilator with pll = 32mhz
    Code work 100%
       asm
          __CONFIG    _CONFIG1H, _OSC_INTIO7_1H & _IESO_OFF_1H
          __CONFIG    _CONFIG2H, _WDT_OFF_2H & _WDTPS_512_2H
          __CONFIG    _CONFIG3H, _PBADEN_OFF_3H
          __CONFIG    _CONFIG4L, _LVP_OFF_4L & _XINST_OFF_4L
          __CONFIG    _CONFIG5L, _CP0_ON_5L & _CP1_ON_5L & _CP2_ON_5L & _CP3_ON_5L
          __CONFIG    _CONFIG5H, _CPB_ON_5H
       endasm
       DEFINE   HSER_RCSTA    90h
       DEFINE   HSER_TXSTA    20h
       DEFINE   HSER_BAUD     9600
       DEFINE   HSER_CLROERR  1
       Led               var   PORTC.4
       I                 Var   WORD
       J                 Var   BYTE
    Boot:
       DEFINE OSC 32
       OSCCON = %11110000                           ' 8 Mhz, internal osc
       OSCTUNE = %11000000                          ' 4x PLL enabled
       CMCON = 7
       ADCON1 = 15                                  ' Port A digital
       INTCON2.7 = 0                                ' Ativa Pull-Ups
       LATA = 0
       LATB = 0
       PORTA = 0
       TRISA = %00000000
       PORTB = 0
       TRISB = %10101110
       PORTC = 0
       TRISC = %10000000
       Led = 1
       pause 2000
       hSEROUT ["-"]
       PAUSE 1
       hSEROUT ["START", 13, 10]
       pause 1
       Led = 0
       i = 0
    Loop:
       Hserout[65 + I, 13]
    Goto Loop
    i try....not work
       asm
    i try .....
          .. __CONFIG    _CONFIG1H, _HS_OSC_1H
          .. __CONFIG    _CONFIG1H, _HSPLL_OSC_1H
          .. __CONFIG    _CONFIG1H, _RC_OSC_1H
          .. __CONFIG    _CONFIG1H, _OSCS_ON_1H & _RC_OSC_1H
          .. __CONFIG    _CONFIG1H, _OSCS_OFF_1H & _HS_OSC_1H
          .. __CONFIG    _CONFIG1H, _RCIO_OSC_1H
          __CONFIG    _CONFIG2H, _WDT_OFF_2H & _WDTPS_128_2H
       endasm
       Led               var   PORTC.4
       I                 Var   WORD
       J                 Var   BYTE
    Boot:
       DEFINE OSC 32
       '-- disable in 252 OSCTUNE = %11000000                          ' 4x PLL enabled
       '-- disable in 252 CMCON = 7
       LATA = 0
       LATB = 0
       PORTA = 0
       TRISA = %00000000
       PORTB = 0
       TRISB = %10101110
       PORTC = 0
       TRISC = %10000000
       Led = 1
       pause 2000
       hSEROUT ["-"]
       PAUSE 1
       pause 1
       Led = 0
       i = 0
    Loop:
       Hserout[65 + I, 13]
    Goto Loop
    ..: Don't worry, be happy :..
  1. A/D conversion with PIC18F67J50
    By ScaleRobotics in forum mel PIC BASIC Pro
    Last Post: - 8th May 2009, 01:48
  2. 18F4550 Bootloader enter via eeprom setting
    By bradb in forum mel PIC BASIC Pro
    Last Post: - 22nd November 2008, 23:51
  3. Error 0X0000008E when connecting a 18F2550 USB HID
    By FranciscoMartin in forum USB
    Last Post: - 16th October 2008, 17:20
  4. PortE problems (PIC18F4455)
    By RubenR in forum mel PIC BASIC Pro
    Last Post: - 12th July 2006, 15:26
  5. Installation sequence
    By Demon in forum General
    Last Post: - 11th July 2006, 03:56
