18F252 config
Results 1 to 6 of 6
Thread: 18F252 config
    All possible/relevant CONFIG fuses options are listed at the end of the MPASM .INC files for your particular PIC. Those should help you figure out which ones you need and which ones are incorrect (whether it be spelling, options that are/aren't present, etc).
    And exactly what is your question? Having trouble decoding the English...
    What isn't working right? What error messages?
    Sep 2006
    Venezuela - Caracas
    The real problem is i need that my 18f252 work with internal oscilator and 32mhz,
    in pic18d2520 i use config above and work 100%
    asm
    __CONFIG _CONFIG1H, _OSC_INTIO7_1H & _IESO_OFF_1H
    and
    DEFINE OSC 32
    OSCCON = %11110000 ' 8 Mhz, internal osc
    OSCTUNE = %11000000 ' 4x PLL enabled
    i need help for corret config in 18F252
    ..: Don't worry, be happy :..
    Sep 2005
    Campbell, CA
    Charles Linquist
    This is cut & paste directly from the 18F252 data sheet:
    2.1 Oscillator Types
    The PIC18FXX2 can be operated in eight different Oscillator modes. The user can program
    three configuration bits (FOSC2, FOSC1, and FOSC0) to select one of these eight modes:
    1. LP Low Power Crystal
    2. XT Crystal/Resonator
    3. HS High Speed Crystal/Resonator
    4. HS + PLL High Speed Crystal/Resonator with PLL enabled
    5. RC External Resistor/Capacitor
    6. RCIO External Resistor/Capacitor with I/O pin enabled
    7. EC External Clock
    8. ECIO External Clock with I/O pin enabled
    Note there is no internal oscillator option for the 252. Oops...;o}
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Sep 2006
    Venezuela - Caracas
    thaks all for help.......realy 452 not have internal oscilator.......vendor sad 252 = 2520
    arggggggggg.....i'm a donkey....i not read pdf
  1. A/D conversion with PIC18F67J50
    By ScaleRobotics in forum mel PIC BASIC Pro
    Last Post: - 8th May 2009, 01:48
  2. 18F4550 Bootloader enter via eeprom setting
    By bradb in forum mel PIC BASIC Pro
    Last Post: - 22nd November 2008, 23:51
  3. Error 0X0000008E when connecting a 18F2550 USB HID
    By FranciscoMartin in forum USB
    Last Post: - 16th October 2008, 17:20
  4. PortE problems (PIC18F4455)
    By RubenR in forum mel PIC BASIC Pro
    Last Post: - 12th July 2006, 15:26
  5. Installation sequence
    By Demon in forum General
    Last Post: - 11th July 2006, 03:56
