Define LCD_DREG PORTB
'Set starting data bit
Define LCD_DBIT 4 'rb4,rb5,rb6,rb7
'Set LCD RS Port
DEFINE LCD_RSREG portb
'Set LCD RS Bit
define LCD_RSBIT 3
'Set LCD Enable Port
Define LCD_EREG portb
'Set LCD Enable Bit
Define LCD_EBIT 2
'Set number of LCD Lines
Define LCD_LINES 2
'Set Command Delay time in uS
define LCD_COMMANUS 2000
'Set Data delay time in uS
define LCD_DATAUS 50
' Set Hardware Directions
CMCON=%00000111 ' Disable Comparators
TRISA=%00000111 ' PORTA all set to Output
UP var PORTA.0 ' Press to Decrement Button
Enter var PORTA.1 ' Press to Set/memorise Button
Down var PORTA.2 ' Press to Increment Button
CounterC var Byte
LCDOut $FE,1 ' Clear LCD
CounterC=0 ' Set to Start of Setup (seven steps from 0 to 6)
SetupLoop:
LCDOut $FE,1,"Set "
If CounterC=0 then
LCDOut "Real Time"
If CounterC=1 then
LCDOut "On Time"
If CounterC=2 then
LCDOut "Off Time"
If CounterC=3 then
LCDOut "Date"
If CounterC=4 then
LCDOut "Day Temp"
If CounterC=5 then
LCDOut "Night Temp"
If CounterC=6 then
LCDOut "MODE"
SetupDisplayLoop:
If Enter = 1 then
if CounterC=0 then Set_time
If counterC=1 Then Set_ontime
if counterC=2 Then Set_offtime
if counterC=3 Then Set_Date
if counterC=4 Then Set_dtemp
if counterC=5 Then Set_ntemp
if counterC=6 Then Set_Btemp
if enter = 1 then
counterC = counterC + 1
if counterC >= 7 then
counterC = 0
goto setupLoop
Set_time:
Set_ontime:
Set_offtime:
Set_Date:
Set_dtemp:
Set_ntemp:
Set_Btemp:
