Hi all.
I am using a PIC16F767 to control some 12V light strips of LEDS. It will use the HPWM at the lowest available frequency at 4Mhz which is around 250Hz to control light dimming
The FULL 100% Duty Cycle load will be close to 15amps at 12V DC....
Can anyone suggest or guide me in the right direction for the right type of switching device?
I have quite a few Motorola TIP Series Power transistors around (TIP120,121,122)
I linked up only 1/4 of the lights so load would have been around 4amps. But I have successfully blown them up by overheating them, even on a massive fan cooled heatsink.
The TIP 121 datasheet says that it is a low speed medium power general purpose amplifier/switching transistor. Is 250Hz considered low speed for this type of transistor?
What are the forum members using to PWM high amperage loads?
Obviously I am doing something incorrectly or wrong part choice...
