PIC16F917 - Not reading input
Results 1 to 7 of 7
    Feb 2008
    Default PIC16F917 - Not reading input
    All,
    I am trying to read the input from RA7 from the PIC16F917. The problem is that I cannot do so. Does anyone know why? Thanks-N-Advance
    INCLUDE "modedefs.bas"
    DEFINE OSC 4 'SET OSCILLATOR SPEED TO 4 MHz
    OSCCON = %01100111 'Enable internal oscillator
    LCDCON=$40 'DISABLES LCD
    CMCON0=$07 'DISABLES COMPARITORS
    TRISA = %10101111 'Set PORTA IO Ports (0 = output, 1 = input)
    MAIN:
    PAUSE 1000
    SEROUT PORTc.1,N9600,[13,10,"pic_mon = ",#PORTA.7,13,10]
    GOTO MAIN
    What do you have A.7 connected to? What are you expecting?
    And the internal OSC may not be good enough for serial. What are you sending to?
    This chip has ADCON0, ADCON1, and ANSEL registers, all affect PortA
    Feb 2008
    mackrackit...
    What do you have A.7 connected to? I have it connected to a GPIO which outputs 3.3VDC
    What are you expecting? Either a logic 1 or 0
    And the internal OSC may not be good enough for serial. What are you sending to? I am sending to the com port on the PC, it outputs the message i want.
    Quote Originally Posted by freddayz View Post
    What do you have A.7 connected to? >>>I have it connected to a GPIO which outputs 3.3VDC
    Well, that isn't going to be near enough voltage to connect into an RS232 port on a PC... A 5v signal is just barely enough, but seems to work in most cases. Either need to bump up to 5v or use a 3v-compatible MAX232-type chip in the middle.
    And the internal OSC may not be good enough for serial. What are you sending to? >>>I am sending to the com port on the PC, it outputs the message i want.
    Internal oscillators are sometimes accurate enough for serial communications, sometimes not. Best bet is to use an external oscillator.
    Feb 2008
    I guess my question is not clear then...
    I am trying to program RA7 on the PIC16F917 as an input with no success all I read is 0
    As Joe mentioned about the ADC.
    Take a look at this:
  1. Sony LanC Program
    By l_gaminde in forum Code Examples
    Last Post: - 25th September 2009, 19:51
  2. floating A/D input
    By muddy0409 in forum mel PIC BASIC Pro
    Last Post: - 28th April 2009, 14:21
  3. Timing input pulses and re-outputting them
    Last Post: - 28th February 2007, 02:50
  4. Using LEDs as light sensors
    Last Post: - 30th December 2006, 23:19
  5. 16F88 reading Analog Input
    By thunderstrike44 in forum mel PIC BASIC Pro
    Last Post: - 30th August 2004, 23:41
