Reading analogs with 16F877
Results 1 to 11 of 11
    Default Reading analogs with 16F877
    I am trying to read 4 Analog inputs with a pic and deliver them out on a hardware serial port. For some reason nothing happens. I am new to the 16F877 any help would be apreciated.
    INCLUDE "MODEDEFS.BAS"
    INCLUDE "ANSI.INC"
    DEFINE OSC 20 ' Define crystal as 20Mhz
    '*Serial port Setup 9600 8N1*
    DEFINE HSER_BAUD 9600 ; 9600 Baud
    DEFINE HSER_CLROERR 1 ; Clear overflow automatically
    'Define ACDIN parameters
    Define ADC_BITS 10 ' Set number of bits in result
    DEFINE ADC_CLOCK 3 ' Set clock source ( 3 = RC )
    DEFINE ADC_SAMPLEUS 50 ' Set sampling time to micro-seconds
    'This Part set PORTA 0-5 an analog inputs
    TRISA = %00011111 'set PORTA 0-5 as inputs
    ADCON1 = %10000000 'Right justify output of ADC use vss and vdd as ref.
    ADCON0 = %11100000 'FRC (clock derived from a dedicated internal oscillator)
    TRISC = %10000000 'RC7 as RX(input) rest as output
    V1 var WORD
    V2 var WORD
    V3 var WORD
    V4 var WORD
    @ ClearScr ; Clear Screen
    ADCIN 0,v1
    ADCIN 1,v2
    ADCIN 2,v3
    ADCIN 3,v4
    HSEROUT [DEC v1,13,10]
    HSEROUT [DEC v2,13,10]
    HSEROUT [DEC v3,13,10]
    HSEROUT [DEC v4,13,10]
    Sep 2007
    USA, CA
    You also have to configure your usart. You are missing the txsta and rxsta settings; read the datasheet and make sure you have all of the settings necessary. For instance, txsta.5 enables transmit...
    Thanks for the info so far i added the folowing two lines but still no joy
    TXSTA = %10100100
    RCSTA = %10010000
    Quote Originally Posted by Andre_Pretorius View Post
    INCLUDE "ANSI.INC"
    V1 var WORD
    V2 var WORD
    V3 var WORD
    V4 var WORD
    ADCIN 0,v1
    ADCIN 1,v2
    ADCIN 2,v3
    ADCIN 3,v4
    Try Add : DEFINE HSER_SPBRG 129
    also do not see any config fuse settings, I am at work so have no access to data sheets, does this chip have ansel ?
    This is what i have so far, Still nothing
    No mention of ansel in the data sheet, any other idea i have replaced the chip also and tested with a ossiliscope to try and see if mabe the chips was faulty still nothing
    TXSTA = %10100100
    RCSTA = %10010000
    TXSTA = %10100100
    RCSTA = %10010000
    RC6 output, RC7 input edit: I gotta rub my eyes ! Been starin' at this "Confuser too long" Anyway you're using Herserout, so you should be using RC6, Yes? So what's on the other end? Is it working? Oh , just nosey, what's in the ansi include file? Must be something of yours, never seen that one . . .
    Cut this from your code and see:
    TXSTA = %10100100
    RCSTA = %10010000
    Current code still nothing
    Hi Andre,
    OK I think I would go to square 1. Open a new window in MCS and put in only the basics, your hser defines, a byte variable, load a value into the variable and then an HSEROUT statement, also the config statements, and OSC define. see if that works, no includes, no AD enable code, in fact disable for this test, then after this works, start adding stuff back in.
    Just a bit more info here is the inc file i am using, in answer to JOE s question the the device on the other side is my PC running hyper terminal
    NOLIST
    ifdef PM_USED
    LIST
    include 'M16F87x.INC' ; PM header
    device pic16F877, hs_osc, wdt_on, pwrt_on, lvp_off, protect_off
    XALL
    NOLIST
    LIST
    LIST p = 16F877, r = dec, w = -302
    INCLUDE "P16F877.INC" ; MPASM Header
    __config _HS_OSC & _WDT_ON & _PWRTE_ON & _LVP_OFF & _CP_OFF
    NOLIST
    LIST
    thanks Joe s i did it but still nothing, I am now running a new PIC with LED's on the TX and RX lines just to elimenate any hardware problems here is the current code
    HSEROUT ["hallo"]
    Talking
    Thank you JOE S i found the problem, i went back to a led and a button when that did not wanted to work i went back to the hardware and found i used the wrong caps on the oscilator fixing it solved all the problems. again thank you for all the help
  1. 16f877 and ps/2 keyboard error???
    By boraciner in forum mel PIC BASIC Pro
    Last Post: - 5th July 2009, 09:14
  2. Replies: 8
    Last Post: - 5th May 2009, 21:10
  3. DS18B20 error reading
    By Gaetano in forum mel PIC BASIC Pro
    Last Post: - 29th August 2007, 17:21
  4. Pot reading jumping like crazy!!!
    By champion in forum mel PIC BASIC Pro
    Last Post: - 20th November 2006, 22:24
  5. 4 Quadrant dc drive with 16F877
    By mns45 in forum mel PIC BASIC
    Last Post: - 23rd February 2006, 14:05
