HSEROUT problem
Results 1 to 16 of 16
Thread: HSEROUT problem
    Default HSEROUT problem
    I am trying to operate my solenoid to lock/unlock VIA SMS, but i have errors like
    ERROR: Macro HSEROUT2?T not found in macro file.
    ERROR: Macro HSEROUT2?C not found in macro file.
    ERROR: Macro HSEROUT2COUNT?C not found in macro file.
    ERROR: Macro HSEROUT2NUM?B not found in macro file.
    ERROR: Macro HSEROUT2DEC? not found in macro file.
    i read quite afew forums on HSEROUT problems but none address to such.
    is there any solutions to such errors??
    thx
    Oct 2003
    holland
    Please post your complete code in a code window here, then we can see what you forgot in your code.
    Default THX Mat
    here is my code as my board could not read serin and serout, i have no choice but to use other alternative like hserout.
    ' Hardware Defines *
    'PIC16F876A specific
    ;__config _XT_OSC & _WDT_ON & _PWRTE_ON & _MCLRE_ON & _LVP_OFF & _CP_OFF
    DEFINE LOADER_USED 1
    DEFINE OSC 20
    DEFINE HSER_BAUD 9600
    DEFINE HSER_RCSTA 90h
    DEFINE HSER_TXSTA 24h
    DEFINE HSER_SPBRG 129
    DEFINE HSER_CLROERR 1
    ' Define program variables *
    NumLen var byte ' Tel Number length
    PhoneNo var byte[16]' Phone Number string
    SPhoneNo var byte[16]' Phone number in SMS
    Index var byte ' Index of the SMS
    Cmd var byte[7] ' The command
    X var byte ' Temp Var
    MsgType var byte
    position var byte
    ' Inputs / Outputs & Port Assignments *
    Tx var PORTB.6 ' Tx Rs232 to Terminal
    Rx var PORTB.7 ' Rx Rs232 from Terminal
    ' Set TRIS and system REGISTERS *
    TRISB=%11111111 ' Port B input
    TRISC=%00000000 ' Port C output
    'Message to be send: LOCK and UNLOCK
    InitModem:
    gosub init
    Begin:
    MsgType = 0
    LOOP:
    PORTC.7 = 0
    GOSUB ChkSMS
    GoSUB Read_input
    PAUSE 10000
    IF MsgType=0 then
    GOTO LOOP
    ' Subroutines *
    ' SMS Subroutines
    Init:
    ' Subroutine to initialise the module
    HSerout2 [Tx,84,"AT",13] ' CLIP command
    SERIN2 Rx,84,5000, Problem,[Wait ("OK",13)] ' Loopback to NotReady
    HSerout2 [Tx,84,"AT+CLIP=1",13] ' CLIP command
    Pause 500
    HSerout2 [Tx,84,"AT+CNMI=3,0",13] ' SMS now not polled
    Pause 500
    HSerout2 [Tx,84,"AT+CMGF=1",13] ' Set Text Mode
    Pause 500
    'Preferred Message Storage: ME on Phone
    HSerout2 [Tx,84,"AT+CPMS=",34,"ME",34,13] ' Changed for GR47
    Pause 4000
    'Set the storage to SIM
    HSerout2 [Tx,84,"AT+CPBS=",34,"SM",34,13] ' Otherwise cannot read memory loc1
    'Select Character Set “UTF-8” : Universal text format, 8 bits
    HSerout2 [Tx,84,"AT+CSCS=",34,"UTF-8",34,13] ' for @ sign problem
    HSerout2 [Tx,84,"AT&W",13] 'Store User Profile to non volatile memory
    'HSerout2 Tx,84,"AT+CMGD=1,4",13
    'pause 1000
    ChkSMS:
    HSEROUT2 [Tx,84,"AT+CMGL=",34,"ALL",34,13]
    SERIN2 Rx,84,2500,OutSMS,[Wait("MG")]
    gosub rdsms
    OutSMS: 'no sms received
    RdSMS:
    ' at+cmgl="ALL"
    ' +CMGL: 1,"REC UNREAD","+60123288328","PEC 9720 A","03/05/09,12:10:59+32",145,5
    ' Test1
    ' +CMGL: 2,"REC UNREAD","+60123288328","PEC 9720 A","03/05/09,12:13:27+32",145,5
    ' Test2
    ' OK
    SERIN2 Rx,84,1500,KL_SMS,[Wait(":"),Skip 1,DEC Index]
    SERIN2 Rx,84,1500,KL_SMS,[Wait(34),Wait(","),Skip 2,STR PhoneNo\12,Wait(10),STR Cmd\4]
    SERIN2 Rx,84,4000,WAITOK,[Wait("OK")]
    gosub chknumlen ' check number length again
    pause 10000
    Gosub SendMsg
    KL_SMS:
    ' If I got an SMS I have to Kill it now
    IF Index=0 Then return
    pause 5000
    HSerout2 [Tx,84,"AT+CMGD=",DEC Index,13]
    index=0
    ChkNumLen:
    ' Here I check the Length of Phone Number String
    ' Now determine the PhoneNo string length by looking for the inv commas
    For x=1 to 15
    IF PhoneNo[x]=34 Then
    NumLen=x
    Endif
    Next x
    NumLen=16 ' cant Find so must be 16
    if PhoneNo[0]=34 then Numlen=0 ' we look for ""
    SendMsg:
    GoSub ChkMsgType
    Select case MsgType
    case 1:
    GOSUB LOCK
    CASE 2:
    GOSUB UNLOCK
    end select
    pause 10000
    MsgType=0
    'HSEROUT2 Tx,84,["AT+CMGS=",34,STR PhoneNo\NumLen, 34,13]
    'HSERIN2 Rx,84,4000,Problem, [Wait(">")]
    'Select case 1
    ' case 1:
    ' HSEROUT2 Tx,84,["Message received OK", $1a]
    ' CASE 2:
    ' HSEROUT2 Tx,84,["Message received Fail", $1a]
    'end select
    ChkMsgType:
    IF Cmd[0]="L" && Cmd[1]="O" && Cmd[2]="C" && Cmd[3]="K" Then
    MsgType = 1
    IF Cmd[0]="U" && Cmd[1]="N" && Cmd[2]="L" && Cmd[3]="O" && Cmd[4]="C" && Cmd[5]="K" Then
    MsgType = 2
    MsgType=0
    LOCK:
    PORTC.7 = 1
    pause 5000
    UNLOCK:
    PORTC.7 = 0
    pause 5000
    ''*************** Manual control of servo using push-buttons*******************
    Read_input:
    if PORTB.7 = 0 then
    PORTC.6 = 0
    if PORTB.7 = 1 then
    PORTC.6 = 1
    pause 50
    goto Read_input
    BKERROR:
    GOTo BKERROR
    WAITOK:
    GOTo WAITOK
    Problem:
    Pause 1000
    GOTO Problem
    thx for the post, but constructive help please
    seriously important.
    Oct 2003
    holland
    First of all The used chip has only 1 hardware uart so HSERIN and HSEROUT without the 2 behind is normaly used.
    Then you combine behind the HSEROUT the modifiers of the SEROUT command.
    I can tell you ofcource what you had to type, but you will learn more by yourself if you read the exact used modifiers used for the HSEROUT (HSERIN) command and the SEROUT (SERIN) command and what is the difference beteween those two commands.
    You can find it in the book that came with the compiler or you can download it by www.melabs.com
    hey mat,
    thx for the help but i still dun quite get it.
    meaning that my HSEROUT is code wrongly??
    am i missing something??
    i meant i dun quite get this part
    "without the 2 behind is normaly used.
    Then you combine behind the HSEROUT the modifiers of the SEROUT command."
    Oct 2003
    holland
    Indeed.
    Look into the documents and you see:
    HSEROUT [Item{,item....}] as HSEROUT [data1] when more HSEROUT [data1, data2, data3]
    SERIN Pin,Mode,{Timeout,Label,}{[Qual...],}{Item...}
    The Hser... commands are already defined by the statements:
    I hope you understand what I meant to say.
    In your programm you made a mix of the the both.
    hey mat,
    thx for all the help.
    so how should i go about changing the codes??
    basically i nv use HSEROUT before,
    so i dun really understand it.
    skimask's Avatar
    skimask Guest
    Quote Originally Posted by Williamaybe View Post
    There's no reason why you can't use SEROUT in place of HSEROUT, just configure the I/O as general purpose rather than a serial port.
    And you're trying to user HSEROUT2. If you read your PBP manual, you'll see that HSEROUT2 is reserved for PICs with 2 hardware serial port modules, something that the 16F876A does NOT have.
    thx ski for telling me that.
    but seriously i dunno why.
    when i write serout and serin,
    my programme doesnt really function as expected.
    "my modem does receive the message that i send
    but somehow there is no output"
    is there any problems with it??
    skimask's Avatar
    skimask Guest
    Like Mat said earlier, your usage of the HSEROUT command is almost totally incorrect. RTFM applies in this case...or even look at the command structure in the manual, or Mat's post earlier.
    hey ski and mat,
    thx for all ur help.
    but i guess im kinda slow in getting it.
    wats RTFM supposed to mean??
    i dun quite get it
    still i gt 1 small problem.
    is there difference between a receiving and transmitting code??
    cuz recently i wrote a transmitting code,
    its able to send sms, but when i save the same thing for receiving. it doesnt work.
    and lastly,
    wat does
    "Define ONINT_USED 1 'Serves as LOADER_USED for versions before 2.33 "
    supposed to mean.
    skimask's Avatar
    skimask Guest
    hey ski and mat,
    i dun quite get it
    and lastly,
    wat does
    supposed to mean.
    RTFM = Read The F...... Manual
    Is there a difference between receiving and transmitting code?
    Is there a difference between talking and listening?
    Which version of PBP are you running?
    the serious part is,
    i dun haf a manual.
    thats why im tryin to figure my way out.
    i duno anythin abt writing programme.
    PBP??
    im using microcode studio to write my program.
    skimask's Avatar
    skimask Guest
    i dun haf a manual.
    PBP??
    Microcode Studio is a Suite, a front end for other programs, nothing more than a fancy editor (albiet a FANCY editor that handles a lot of stuff for you).
    PBP is the compiler, MPLAB/MPASM (or PM) is the assembler, and you have your choice of a bunch of programmers.
    So, which version of MCS, PBP, MPLAB/MPASM are you using?
    Which programmer?
    hey ski,
    im using PicBasic Pro
    but i duno wat version.
  1. I2C Slave with a PIC
    By ralfmayr in forum mel PIC BASIC Pro
    Last Post: - 21st August 2016, 17:44
  2. HSEROUT and Commas, What? Help Me Understand
    By altech6983 in forum mel PIC BASIC Pro
    Last Post: - 20th July 2009, 19:12
  3. Is HSEROUT corrupting bit 7 ?????
    By Robert Wells in forum mel PIC BASIC Pro
    Last Post: - 23rd October 2008, 16:26
  4. HSEROUT Problem
    By Keith in forum General
    Last Post: - 25th June 2005, 15:09
  5. Advantages of HSerout over Serout2 and a problem
    By rpstroj in forum mel PIC BASIC Pro
    Last Post: - 11th August 2004, 22:19
