Schottky for surge & polarity protection?
Results 1 to 8 of 8
    Have a look at the file I attached. I think it is exactly what you want.
    USA - Arizona
    Exclamation Understand the uses of TVS and Schottky Devices
    Transorbs (like SMBJ) and other TVS (transient volt suppressors) are great for transients. In fact, for lightning protection and such TVS devices are used widely (these are what you find in your surge protection power strips). Schottky diodes would never whidstand lightning transients (and live to see another day).
    But schottly diodes have very little capacitance, transorbs generally have a great deal of capacitance. So if you hang a transorb directly across the antenna input, you may as well not worry about reception / transmission (since you will have none).
    In your case, a schottky diode in an anti-parallel configuration (as was suggested) maybe all you need. Should you require to add the TVS (there are some very good bidrectional ones - look up AVX's TVS) to the antenna line, you will want to have an RF choke (RF inductor) in series with the TVS. The choke connects between the antenna line and TVS, and the TVS betweeb the choke and power rail (GND most likely). Lookup the following appnotes, they have very good info:
    What is a Silicon TVS and How Does it Work?
    Selecting the Optimum Transient Voltage Suppressor
  1. Presetting Configuration Fuses (PIC Defines) into your Program
    Last Post: - 15th December 2013, 09:54
  2. Error 0X0000008E when connecting a 18F2550 USB HID
    By FranciscoMartin in forum USB
    Last Post: - 16th October 2008, 17:20
  3. PICBasic newbie problem
    Last Post: - 12th February 2008, 00:55
  4. angular speed and gyrometer
    By fefenin in forum mel PIC BASIC
    Last Post: - 26th March 2007, 21:04
  5. Installation sequence
    By Demon in forum General
    Last Post: - 11th July 2006, 03:56
