Interrupt On Change - question
Results 1 to 5 of 5
    NOT a problem. And no interrupts required.
    As long as the Global Interrupt Enable is 0 (INTCON.7=0), the program flow will NOT be redirected on a change to to the IOC pins.
    The Interrupt flag (RABIF) will "Latch" on Any change, and the status will be available until the flag is cleared "Manually" in software. So you are free to "Poll" it at your leisure.
    If the condition goes away before the program gets around to looking at it, you can't tell which of the pins actually changed. Which could be a problem in itself, but it sounds like you may not need to know that.
    Aug 2007
    Oooohhh.... okay, well that sounds easy enough. I thought I could turn the interrupt on change on and off for individual pins. Is that only change to other pins on the port, or any pin on the entire pic?
    What if I have a pin set to an output and I'm driving it to do other stuff? That's the kind of "other" change that may happen while waiting for the input pin to trip. For example, I have 4 pins driving LED's as outputs, and my one pin set as an input is left to trip the flag?
    You've got me pointed in the right direction at least. Thanks!
    Only four pins on PortB have the interrupt on change capability and the interrupt is tripped when either one of those four changes state (if enabled). On the 16F677 you can enable/disable the interrupt on change feature for the four pins individually so if you only want one pin to trip the interrupt you simply enable the interrupt for that pin only. See section 4.4.2 in the datasheet for more info on how you do that.
    Older PICs like the 16F877 doesn't allow you to enable the interrupt for indvidual pins like you obviously can on the 16F677 - nice feature.
    HTH
    Aug 2007
    Outstanding. Thanks so much. That makes my job easy.
  1. A Simple IOC Routine (Interrupt On Change)
    By lugo.p in forum mel PIC BASIC Pro
    Last Post: - 8th March 2010, 20:53
  2. Interrupt question
    By ultiblade in forum mel PIC BASIC Pro
    Last Post: - 26th November 2009, 21:12
  3. Can't ID interrupt source with this IntHandler??
  4. Help with Analog Interrupt
    By brid0030 in forum mel PIC BASIC Pro
    Last Post: - 13th February 2008, 19:14
