MCSP with USB to RS-232 converter
Results 1 to 7 of 7
    Default USB to RS-232, MCSP not working
    Hi Dave,
    Thanks for the tip. I have now tested the RS-232/USB converter as you suggested with Auto, 19,200 bps and 115,200 bps. About one attempt in 10 gets through in Auto or 115,200 bps. None has worked at 19,200 bps.
    I get from 1 to 6 green 'progress' squares then MicroCode Loader hangs. After a Ctrl/Alt/Del the Task Manager shows MicroCode Loader is not responding.
    I suspect that different USB/RS232 converters have different internal or end-to-end delays and although a converter may be able to sustain high speeds, long delays might run foul of some MCSP timing assumptions.
    I still cannot get the ASUS or the Sony VAIO to program a PIC 18F4620 using PBP 2.50b and provided with MCSP 3.0.0.5.
    Still hopeful.
    BrianT
    Default Problem licked - for now
    I bought another USB to RS-232 converter. The first one cost $25, the later one cost $19.95 and it works! Seems you can pay too much for a USB to RS-232 converter.
    I am firmly of the belief that MCS Loader is time sensitive and it is pot luck whether the converter you buy has a short or long internal delay. Both the converters I have tried claimed 1 Mbps throughput so raw speed is not the issue.
    The one that worked came from Electus, part number XC4834. The package is labeled GUC-AD9.
    HTH
    BrianT
  1. USB CDC Communications for Dummies!
    By Squibcakes in forum USB
    Last Post: - 15th January 2014, 14:43
  2. Simple USB Comms Problem
    Last Post: - 6th January 2010, 21:17
  3. serial to usb converter
    By nicjo in forum Serial
    Last Post: - 18th September 2008, 00:52
  4. USB to COM converter
    By iugmoh in forum USB
    Last Post: - 20th April 2008, 15:19
  5. Serial to USB converter
    By jrt4fun in forum USB
    Last Post: - 8th August 2005, 16:14
