Don't give them away yet.
Did you know that the PBP I2C commands don't use the Hardware MSSP module?
You can still use I2CREAD and I2CWRITE.
Darrel
No I didn't know that, I have been using the MSSP pins and figured that was the way it had to be.
The code I have written works on the 877A and 887 but not on the 4450. I am reading and writting to EEPROM.
I am currently using this to set the ports. (LAB-X1 board)
DataPin var PORTC.4
ClkPin var PORTC.3
I inserted the 4450 and programmed it, everything worked except the writting to EEPROM.
Guess I should have looked a little more closely at the datasheets. Pins changed in 4450, so no I2C on LAB-X1 Board.
877a - Pin18 - SCL - c3
Pin23 - SDA - c4
4450 - Pin18 - Vusb - Input
Pin23 - c4
Waiting for a few remaining parts to be able to start using Breadboard, then I can get off of the hardwired ports on the LAB-X1.
Thanks for your timely help there Darrel.![]()
Last edited by manwolf; - 9th July 2008 at 21:47. Reason: Opened eyes and looked at Datasheets.
> ... be able to start using Breadboard, then I can get off of the hardwired ports on the LAB-X1.
Ahhhh, freedom at last.
And, while I've never owned a LAB-X1 ... I think it's possible to cut the trace in-between the header rows, to isolate the pin from the peripherals. Then the peripherals can be wired to any other pin as needed.
I've seen it done before to allow using a 16F84 on the Lab-X1. (ICSP pins are different)
For RC3 its P2 pins 15-16, RC4 is P3 pins 15-16.
HTH,
I have already 'wired' alot of stuff out to a breadboard. But I kind of like the little guy and don't want to start doing major surgery just yet.
Maybe next month
Now the EasyPic5 is a horse of a different color, I would do major surgery on it in a heartbeat.
I think it will end up in the parts bin before its over.
I have found the LAB board much easier to work with than the EasyPic. I think the switches adds more confusion to everything. My little pea brain can handle only having one chip in a socket at time.
I have a zif socket for the EasyPic and a few other ideas to make it more userfriedly for a future project.
Any suggestions for a power supply, I am currently using a 12v laptop powersupply and one of those cheap wall adapters from Radio Shack. The laptop supply is rated at 3 amps and appears to be clean enough for my projects so far.
Probably a wise precaution.
Could be a large number of answers to that question. And in the past I've used many different types. But these days, it's almost exclusively the little 5v "Switching" power supplies left over from dead routers, USB hubs etc that seem to only last about 3-5 years. The equipment dies, but the power supplies last forever.
Not all of them are switching, and not all are 5V. But the ones that are, work perfect for everything I've needed.
They have excelent isolation, fairly good regulation (4.8-5.2V), and usually a fairly high current output compared to a Transformer type "Wall Wart" that's twice the size.
Only rule is ... Measure the voltage and polarity BEFORE connecting to anything.
