Question about 18F4450
Results 1 to 14 of 14
    The 18F4550 has analog functions on PORT's A, B and E.
    ADCON1=%00000111
    Doesn't turn them all off.
    May 2008
    Florida
    Darrel
    Provided the right clue, I had overlooked one PORT. Reread the datasheet and discovered the error of my ways.
    ADCON1 = %00001111 did the trick.
    Thank you kind sir.
    May 2008
    Florida
    Also overlooked the fact that I ordered the wrong PIC. I wanted a 18F4550 but ordered 18F4450 and then couldn't figure out why no I2C. 4550 has and 4450 does not.
    If someone needs a couple of 18F4450 let me know.
    Don't give them away yet.
    Did you know that the PBP I2C commands don't use the Hardware MSSP module?
    You can still use I2CREAD and I2CWRITE.
    May 2008
    Florida
    Darrel
    No I didn't know that, I have been using the MSSP pins and figured that was the way it had to be.
    The code I have written works on the 877A and 887 but not on the 4450. I am reading and writting to EEPROM.
    I am currently using this to set the ports. (LAB-X1 board)
    DataPin var PORTC.4
    ClkPin var PORTC.3
    I inserted the 4450 and programmed it, everything worked except the writting to EEPROM.
    Guess I should have looked a little more closely at the datasheets. Pins changed in 4450, so no I2C on LAB-X1 Board.
    877a - Pin18 - SCL - c3
    Pin23 - SDA - c4
    4450 - Pin18 - Vusb - Input
    Pin23 - c4
    Waiting for a few remaining parts to be able to start using Breadboard, then I can get off of the hardwired ports on the LAB-X1.
    Thanks for your timely help there Darrel.
    Last edited by manwolf; - 9th July 2008 at 20:47. Reason: Opened eyes and looked at Datasheets.
    > ... be able to start using Breadboard, then I can get off of the hardwired ports on the LAB-X1.
    Ahhhh, freedom at last.
    And, while I've never owned a LAB-X1 ... I think it's possible to cut the trace in-between the header rows, to isolate the pin from the peripherals. Then the peripherals can be wired to any other pin as needed.
    I've seen it done before to allow using a 16F84 on the Lab-X1. (ICSP pins are different)
    For RC3 its P2 pins 15-16, RC4 is P3 pins 15-16.
    HTH,
    May 2008
    Florida
    I have already 'wired' alot of stuff out to a breadboard. But I kind of like the little guy and don't want to start doing major surgery just yet.
    Maybe next month
    Now the EasyPic5 is a horse of a different color, I would do major surgery on it in a heartbeat.
    I think it will end up in the parts bin before its over.
    I have found the LAB board much easier to work with than the EasyPic. I think the switches adds more confusion to everything. My little pea brain can handle only having one chip in a socket at time.
    I have a zif socket for the EasyPic and a few other ideas to make it more userfriedly for a future project.
    Any suggestions for a power supply, I am currently using a 12v laptop powersupply and one of those cheap wall adapters from Radio Shack. The laptop supply is rated at 3 amps and appears to be clean enough for my projects so far.
    Jul 2005
    Quote Originally Posted by manwolf View Post
    Funny you say that, I just completed a project where I made the same mistake in ordering the breadboard parts: got 4450 and thought I had 4550's.
    Lead to some funny bugs because I was using a different compiler and there the target mattered (due to the differing ammount of RAM).
    Also, both devices host the same MSSP Module, so hardware I2C is the same on both. (I'm sure of this because I wrote code to use it on the 4450 that recompiled & ran flawlessly once I got the correct 4550's.)
    May 2008
    Florida
    Quote Originally Posted by ErnieM View Post
    ErnieM
    My problem is that the LAB X1 is hard wired as to which pins are I2C, as Darrel pointed out the PBP commands work on any port.
    But MicroChip says no MSSP on 4450.(from their site.)
    0 -UART
    1 -A/E/USART
    0 -SPI
    0 -I2C
    0 -MSSP(SPI/I2C)
    I am going to give the 4450 a shot and see what happens, I can always switch if it doesn't work out.
    Thanks for the info, good to know in the future.
    Jul 2005
    But they say yes to MSSP on page 1 of the data sheet.
    Jul 2005
    Oops... not 4455... you said 4450.
    Never mind.
  1. Remote PIC input question
    By Adrian in forum mel PIC BASIC Pro
    Last Post: - 1st September 2007, 15:44
  2. FREQOUT - PWM question
    By Etcho in forum mel PIC BASIC Pro
    Last Post: - 25th February 2007, 23:51
  3. PIC16F684 Program question
    By Nicholas in forum mel PIC BASIC Pro
    Last Post: - 28th December 2006, 14:30
  4. Question for a math guru
    Last Post: - 22nd November 2006, 09:45
  5. Please answer my first question
    By John_001 in forum Off Topic
    Last Post: - 15th September 2006, 06:49
