Overthinking what must be simple
Results 1 to 10 of 10
    Jul 2006
    Default Overthinking what must be simple
    Hi experts,
    I would like to create a physically changable but otherwise static byte variable by using an 8 pin DIP switch for a 16f877a to "read." (Apply 5V from a common rail to the pins for "ON")
    So, I'd like to set the DIP before power-on to, say, 01111111 to represent the number 127, which will be a critical element but not change for the remainder of the program unless I reset or do some other interrupt. (A hidden away "field changeable" property without the need for displays, etc.)
    Such that the pins on/off will create a variable in the range from 0-255.
    Assuming I have all the pins set to digital, et al, I can't think of how to place the bits from the pins into place.
    This has to be so simple I'll be embarrased, but can anyone clue me in?
    Chris
    Quote Originally Posted by ChrisHelvey View Post
    Hi experts,
    Chris
    Hi Chris,
    This is a fairly well traveled rod from noobieville , what you are diong is BCD and you are correct re: 127. http://melabs.com/resources/articles/bcdnumbers.htm
    http://www.picbasic.co.uk/forum/arch....php/t-66.html
    Here is a program that varies an output time according to BCD input.
        ifndef __12F675
            error "12F675 not selected"
    @ __config _INTRC_OSC_NOCLKOUT & _WDT_OFF & _MCLRE_OFF & _CP_OFF
        PCON = %00000011    ' BOD off, No POR flag set
    DEFINE  NO_CLRWDT 1
        OSCCAL = %1111100   ' SET OSC TO MAXIMUM SET OSC TO 4 MHZ INTERNAL
        CMCON   = 7	        ' Disable Analog Comparators
        ANSEL   = 0         ' Disable A/D module, all digital
        WPU.4 = 0           ' Disable weak pull up on GPIO.4
        B0    VAR word         ' Byte holds 0 - 255 Word 0 - 65535
        X     VAR WORD
        Index VAR BYTE         ' Byte variable only has to hold 0 - 15
        LED   VAR GPIO.5       ' Alias GPIO.5 as LED will wire to
                               ' transister base to control device
        TRISIO = %00011111     ' RA0 to RA3 inputs for DIP switch
        OPTION_REG = %11111111 ' Dis/Enable internal pull-ups Bit 7
                               ' Bits 0-2 prescaler
                               ' Bit 3 prescaler assignment 1 = WDT 0 = TMR0
                               ' Bit 4 TMR0 source edge select bit
                               ' 1 trigger on High to Low
                               ' 0 trigger on Low to High
                               ' Bit 5 TOCS TMR0 clock source select
                               ' 1 = transition on GP2
                               ' 0 = internal clock (CLKOUT)
                               ' Bit 6 INTEDG Interrupt Edge Select
                               ' 1 = Interrupt on rising edge GP2
                               ' 0 = Interrupt on falling edge GP2
                               ' Bit 7 Pullup resistor enable bit
                               ' 1 = disabled 0 = enabled by individual port
                               ' latch values.
         IF (GPIO.4 = 1) THEN
         B0 = 2500 ' Must be a word variable to hold this value
         else      ' HE HE else it,"ain't gonna work!"
         B0 = 250  ' and it will always default to this value!
        Index = GPIO & $0F   ' Read DIP switch AND mask result
        LOOKUP2 Index,[200,300,400,500,600,700,800,900,1000,2000,_
        3000,4000,5000,6000,7000,8000],X ' notice the X variable
        HIGH LED
        PAUSE b0
        LOW LED
        PAUSE X    ' X is a WORD variable so it can store 300 to 8000
    GOTO Main
        POKECODE @$3FF, $50  ' reintroduces osscal correction data
                             ' $3FF tells it where to code, $50 is the
                             ' Cal value unique to each individual chip.
    JS
    Mentor, Ohio
    Smile
    Hi Chris,
    So you have 8 dip switches with one switch on each pin of a port. You want the switch being set to ON to be a high or 5vdc. You would have 8- 4.7K or 10K resistors, again one resistor on each pin with the other side of each resistor going to Gnd. These are called "pull down" resistors.
    Now to read the value set by the switches simply read the "PortValue".
    An example would be:
    PortValue VAR BYTE
    PortC = PortValue
    If PortValue = 127 Then
    You can also use "Select Case" instead of the multiple IF .. Then 's
    You control when the switches get read with your program. I used this setup once a couple of years ago reading the value of a PC card in a card cage from a dip switch setting.
    HTH,
    BobK
    Jul 2006
    Ah yes, I have my residence in NoobieVille and am traversing the road to dangerous and wild lands more frequently than I am comfortable with. He He..
    I knew it had to be simple. So, basically, the whole port is just assigned to a variable.
    ....of course....
    Overthinking the obvious I was!
    If I wanted 16 bits, and thus a word variable, would I simply add them together?
    PortValue VAR WORD
    PortValue = PortB + PortC ???
    Thank you for your reply. Now I can try things I REALLY don't understand. "Heading deep into the mountain canyon."
    Chris
    Jul 2006
    No, wait a minute. Adding won't do it, will it? 01111111 + 01111111 = 11111110
    Hmm....
    Hmm....
    Not sure how you would do it but 2 ports probably make a word something like
    MyVar VAR WORD
    PortB myvar.lowbyte:
    PortC myvar.HiByte . . .
    Jul 2006
    Yeah, that makes sense. I forgot about the lowbyte, HiByte reference.
    No, I don't need that many settings. I was just curious.
    Thanks a lot. I think I can get it done now.
    Chris
    Hmm....
    Yep,
    127 + 127 = 254
    As long as you only use seven bits on each port and add those you will stay below the 255 limit.
    How many combos can you come up with using two 7 bit numbers like that. One heck of a comination lock.
    And, if you wanted to do this with 3 pins instead of 8 add a 165 PISO shift register.
    Check out the lookup table in the program I listed, maybe you dont need so many settings . . .
  1. Simple RF remote control code
    Last Post: - 22nd January 2014, 10:45
  2. A Serial GLCD 128x64 Simple Project
    Last Post: - 8th March 2010, 20:58
  3. Simple Blinking LED - WTF!!
    By johnnylynx in forum mel PIC BASIC Pro
    Last Post: - 1st February 2010, 06:19
  4. Replies: 4
    Last Post: - 7th September 2005, 14:11
  5. Simple Serial communications
    By kitcat in forum mel PIC BASIC Pro
    Last Post: - 18th July 2005, 19:42
