I do not know if this will help, but you are welcome to it.
It uses to tables in code space.
This uses a LM34 for the cold junction and a "K" type thermo-couple.
10 degree F resolution from 510 to 2500. The TC is ran through an op amp.
Even does a little data logging.
'*  Date    : 09/01/2007
'*  Pic   :  18F4320
   DEFINE OSC 20
DEFINE LCD_DREG     PORTC
define LCD_DBIT     0
DEFINE LCD_RSREG    PORTD
DEFINE LCD_RSBIT    1
DEFINE LCD_EREG     PORTD
DEFINE LCD_EBIT     0
DEFINE LCD_BITS     4
DEFINE LCD_LINES    2
DEFINE LCD_COMMANDUS    2000
DEFINE LCD_DATAUS   50
ADCON1= %00011011  '13 'AN0 and AN1
CMCON = 7
TRISC = %10111111
temp1        var byte
temp2        var byte
T1			 var byte
T2           var byte
TC	VAR	WORD
TCT	VAR	WORD
TX	VAR WORD
TXI	VAR WORD
TXIU	VAR WORD
TXIU = 500
T_T	 VAR WORD
A_T VAR WORD
DL	VAR	WORD
BCNT	VAR	WORD
CNT	VAR	WORD
BL		VAR	WORD
CNT = 0
BL = 0
D_C		VAR	WORD
INTCON2.7 = 0
T0CON = %11010111
INTCON = %10100000 'Enable INTE interrupt
On interrupt goto myint
START:
    LCDOUT $FE,1,"MACKRACKIT CONTROLS"
    lcdout $FE,$C0,"PYROMETER V2"
     pause 5000
INTCON.2=0
RUN:
gosub getT1
GOSUB getT2
T1 = temp1
A_T = T1 - 30
T_T = A_T + TXIU
LCDOUT $FE,1,"LM34 ",#T1," A_T ",#A_T
lcdout $FE,$C0,"TC ",#TXIU," T_T ",#T_T
GOSUB D_INDEX
IF TXIU < 1760 THEN M_H
IF PORTD.3 =1 THEN E_D
	GOTO RUN
M_H:
LCDOUT $FE,1,"MORE HEAT "
PAUSE 50
GOTO RUN
getT1:
	ADCON0= %00000001  '$1  '%00000001 AN0
ADCON2.7 = 0
	gosub getAD
	temp1 = ADRESH
getT2:
	ADCON0= %00000101   '$5  '%00000101 AN1
ADCON2.7 = 1
	gosub getAD
	TC.highbyte = ADRESH
	TC.lowbyte = ADRESL
getAD:
	pause 50
	ADCON0.1 = 1
	pause 50
D_INDEX:
TX = TC
'THERMO STEPS
LOOKDOWN2 TX,>[898,895,892,889,886,883,879,876,873,870,867,863,860,857,854,850,_
847,844,841,838,835,832,828,825,822,819,815,812,809,805,802,799,795,792,788,785,_
782,778,775,772,769,765,762,758,755,751,748,744,741,737,734,731,727,724,721,717,_
713,710,706,703,699,696,692,689,685,682,678,675,671,667,664,660,656,653,650,646,_
643,639,635,632,628,624,620,617,614,610,606,603,599,595,592,588,584,580,577,573,_
570,566,562,558,555,551,547,544,540,536,532,529,525,521,517,513,509,506,502,498,_
495,491,487,483,479,475,471,468,464,460,456,453,449,445,441,437,433,429,426,422,_
418,414,410,406,402,398,395,391,387,383,379,375,371,367,363,360,356,352,348,344,_
340,336,332,328,324,321,317,313,309,305,301,297,293,290,286,282,278,274,270,267,_
263,259,255,252,248,244,240,236,232,229,224,221,217,213,209,206,202,198,194,190,_
187,183,180,176,173],TXI
'THERMO TEMPERATURES
LOOKUP2 TXI,[2500,2490,2480,2470,2460,2450,2440,2430,2420,2410,2400,2390,2380,2370,_
2360,2350,2340,2330,2320,2310,2300,2290,2280,2270,2260,2250,2240,2230,2220,2210,2200,_
2190,2180,2170,2160,2150,2140,2130,2120,2110,2100,2090,2080,2070,2060,2050,2040,2030,_
2020,2010,2000,1990,1980,1970,1960,1950,1940,1930,1920,1910,1900,1890,1880,1870,1860,_
1850,1840,1830,1820,1810,1800,1790,1780,1770,1760,1750,1740,1730,1720,1710,1700,1690,_
1680,1670,1660,1650,1640,1630,1620,1610,1600,1590,1580,1570,1560,1550,1540,1530,1520,_
1510,1500,1490,1480,1470,1460,1450,1440,1430,1420,1410,1400,1390,1380,1370,1360,1350,_
1340,1330,1320,1310,1300,1290,1280,1270,1260,1250,1240,1230,1220,1210,1200,1190,1180,_
1170,1160,1150,1140,1130,1120,1110,1100,1090,1080,1070,1060,1050,1040,1030,1020,1010,_
1000,990,980,970,960,950,940,930,920,910,900,890,880,870,860,850,840,830,820,810,800,_
790,780,770,760,750,740,730,720,710,700,690,680,670,660,650,640,630,620,610,600,590,_
580,570,560,550,540,530,520,510,_
500],TXIU
'*****Interrupt Handler *****
Disable 'No interrupts pass this point
myint:
	CNT = CNT + 1
SEROUT2 PORTE.2,16468,[DEC CNT,13,10]
	IF CNT => 1045 THEN   '1830 = 1m 45 s - 10457 = 10 m- 1045 = 1 m
	HIGH PORTD.2
	PAUSE 100
	LOW PORTD.2
	PAUSE 100
	CNT = 0
SEROUT2 PORTE.2,16468,[DEC 11,13,10]
GOSUB	W_D
'PIR1.0=0
INTCON.2 = 0 'clear interrupt flag
resume 'return to main program
enable
W_D:
INTCON = %10000000 'DIS-Enable INTE interrupt
FOR BCNT = 1 TO 10
	HIGH PORTD.2
	PAUSE 100
	LOW PORTD.2
	PAUSE 100
NEXT
BCNT = 0
READ 200, DL.BYTE0
READ 201, DL.BYTE1
'DL = DL + 2
WRITE 200, DL.BYTE0
WRITE 201, DL.BYTE1
WRITE DL, TXIU.BYTE0
WRITE DL+1, TXIU.BYTE1
E_D:
	FOR BL = 1 TO 100
READ 0, D_C.BYTE0
READ 1, D_C.BYTE1
	HIGH PORTD.2
	PAUSE 100
	LOW PORTD.2
	PAUSE 100
LCDOUT $FE,1,"TXIU  ",#D_C
SEROUT2 PORTE.2,16468,["MACKRACKIT ",DEC D_C,"  ",DEC DL,13,10]
NEXT
GOTO RUN
