A Temperature & Humidity Data Recorder Project
Results 1 to 1 of 1
Threaded View
    Jul 2008
    Default A Temperature & Humidity Data Recorder Project
    Hello all,
    This project uses BasicStamp 2P ( also you can use PIC chip ) to interface with a DS1307, SHT15, JP Module and 16x4 LCD display. Code used is standard PBasic 2.5, it should work on most BasicStamp chips.
    The project is a data logger demonstration program. It can record temperature and humidity data to MMC/SD card with date and time. Press the temperature unit select button switch to select Celsius or Fahrenheit. The data can be processed to the virtual XY chart or Polar Chart through the website ( www.jianpingusa.com/jpchart ).
    Components:
    1) Basic Stamp 2P
    Manufactory: www.parallax.com
    Datasheet: http://www.parallax.com/tabid/440/Default.aspx
    2) DS1307
    Manufactory: www.maxim-ic.com ,
    Datasheet: http://datasheets.maxim-ic.com/en/ds/DS1307.pdf
    3) SHT15
    Manufactory: www.sensirion.com
    Datasheet: http://www.sensirion.com/en/pdf/prod...1x_SHT7x_E.pdf
    4) JP Module
    Manufactory: www.jianpingusa.com
    Datasheet: http://www.jianpingusa.com/datasheet...nstruction.pdf
    5) 16x4 LCD Display (CM1644 series)
    Manufactory: http://www.femacorp.com/
    Datasheet: http://www.femacorp.com/Products/LCD...es%20Index.htm
    Data processed website:
    Attached files: ( 5 files )
    1) Project code:
    Please see attach file.
    2) Project schematic:
    3) Project photo
    4) XY Chart:
    Please see attach files.
    5) Polar Chart:
    Video Link:
    Author of this project: OldSpring
    Thanks to picbasic team and all forum users.
  1. Using Nokia LCD
    Last Post: - 3rd May 2018, 04:47
  2. Nokia 3310 display text
    Last Post: - 26th August 2007, 03:39
  3. Big characters on HD44780 4x20
    Last Post: - 7th January 2007, 02:21
  4. LCD + bar graph
    Last Post: - 5th October 2005, 14:50
  5. Sinus calculating !
    Last Post: - 28th November 2004, 23:56
