RA6 & RA7 I/O setting on the 16F88
Results 1 to 36 of 36
    Dec 2007
    Question RA6 & RA7 I/O setting on the 16F88
    I would like to use RA6 & RA7 on the 16F88 as standard I/O. I haven’t been able to figure out (the datasheet is not helping me a lot) how to set the CONFIG1 (FOSC) bit 4, 1 and 0 to (%1XX00) without disturbing other settings. Can someone please explain how to accomplish this.
    Thanks!
    You can find all of the config settings in the *.inc file for the chip by going to program files, microchip, mpasm suite.. find the *.inc for your chip , open in notepad, go towards the end.
    Looks like
    _INTRC_IO
    That should have the internal running and the two pins as I/Os.
    Mentor, Ohio
    Smile
    Hi PICante,
    I had the same problem with the 16F87 which is sister chip to the F88. Do a search for my thread entitled "Internal Osc help" dated January 12, 2007 and look at Bruce's reply. It worked for me.
    HTH,
    BobK
    Now I am confused.
    I went and read the post Bob mentioned and tried it. Did not work.
    I do not have a 16F88 laying around, but set up a project in MPLAB.
    When I use _INTRC_IO and read the config register I have the expected results.
    When I use _INTRC_OSC_NOCLKOUT I get an error and the config register says LP.
    Now I am confused.
    Unless I'm wrong, the P16F88.INC file in the MPASM doesn't have that config directive listed.
    It's got these listed for oscillators:
    ;Configuration Byte 1 Options
    _EXTRC_CLKOUT EQU H'3FFF'
    _EXTRC_IO EQU H'3FFE'
    _INTRC_CLKOUT EQU H'3FFD'
    _INTRC_IO EQU H'3FFC'
    _EXTCLK EQU H'3FEF'
    _HS_OSC EQU H'3FEE'
    _XT_OSC EQU H'3FED'
    _LP_OSC EQU H'3FEC'
    I think you want INTRC_CLKOUT.
    We are looking at the same thing.
    I picked _INTRC_IO because I think that should make the pins I/Os.
    So what was Bruce talking about in Bob's post? The *.inc s are pretty much the same for the 88 and 87.
    Hi Everyone. I've only used the 'F88 once. I didn't have any problem with this header file:
    OSCCON = $60 'set int osc to 4mhz
    ANSEL = 0 'ALL INPUTS DIGITAL
    ADCON0 = 0 'AD MODULE OFF
    CMCON = 7 'COMPARATORS OFF
    TRISA = %SELECT YOUR I/O'S
    TRISB = %SELECT YOUR I/O'S
    @ DEVICE MCLR_OFF, INTRC_OSC, WDT_ON, LVP_OFF, BOD_OFF, PWRT_ON, PROTECT_ON
    Quote Originally Posted by peterdeco1 View Post
    Now I get it...I think.
    INTRC_OSC works when using PM as an assembler.
    _INTRC_IO works with MPASM.
    Dec 2007
    Smile
    Hi guys, thanks for the responce!
    I have been doing a few projects based on the 16F88 and they all have turned out a success until this time, the first time I needed RA6 & RA7 as I/O’s.
    I use MPASAM and the first part of my code looks like this:
    define OSC 8
    OSCCON =%01110000
    @__config_INTRC_IO ‘ added today, compiled OK but no I/O on RA6 or RA7
    TRISB = %00000000
    TRISA = %11001100
    ANSEL = %00000000
    CMCON = 7
    All the other ports works just fine so.....
    Thanks for being here!
    At least it compiles
    Try what skimask suggested
    INTRC_CLKOUT
    Or compile with PM and use
    One of them has to work.
    This chip as 2 ADCON registers too
    Dec 2007
    I tried the “INTRC_CLKOUT” with MPASM it compiled well but still no I/O!
    I use the 16F88.inc file as is, not edited.
    There must be something I miss here; “INTRC_CLKOUT” does not make sense to me (no offence)! The “INTRC_IO” statement seems more logic to me, of curse I might be of the tracks here but that’s how I see it.
    Referring to the 16F88 datasheet page 130 way down;
    Bit 4, 1-0 FOSC<2:0>: Oscillator Selection bits.
    I believe what I need is the fourth alternative:
    “100 = INTRC oscillator; port I/O function on both RA6/OSC2/CLKO pin and RA7/OSC1/CLKI pin”.
    Or… am I loosing it? (apart from my hair!)
    Thanks guys!
    Quote Originally Posted by PICante View Post
    Have you commented out the shebang line in the inc?
    http://www.picbasic.co.uk/forum/show...75&postcount=5
    Dec 2007
    Smile
    This is the last part of my untouched inc file:
    ;       Configuration Bits
    _CONFIG1                     EQU     H'2007'
    _CONFIG2                     EQU     H'2008'
    _CP_ALL                      EQU     H'1FFF'
    _CP_OFF	                     EQU     H'3FFF'
    _CCP1_RB0		     EQU     H'3FFF'
    _CCP1_RB3                    EQU     H'2FFF'
    _DEBUG_OFF                   EQU     H'3FFF'
    _DEBUG_ON                    EQU     H'37FF'
    _WRT_PROTECT_OFF             EQU     H'3FFF'	;No program memory write protection
    _WRT_PROTECT_256             EQU     H'3DFF'	;First 256 program memory protected
    _WRT_PROTECT_2048            EQU     H'3BFF'	;First 2048 program memory protected
    _WRT_PROTECT_ALL             EQU     H'39FF'	;All of program memory protected
    _CPD_ON                      EQU     H'3EFF'
    _CPD_OFF                     EQU     H'3FFF'
    _LVP_ON                      EQU     H'3FFF'
    _LVP_OFF                     EQU     H'3F7F'
    _BODEN_ON                    EQU     H'3FFF'
    _BODEN_OFF                   EQU     H'3FBF'
    _MCLR_ON		     EQU     H'3FFF'
    _MCLR_OFF                    EQU     H'3FDF'
    _PWRTE_OFF                   EQU     H'3FFF'
    _PWRTE_ON                    EQU     H'3FF7'
    _WDT_ON                      EQU     H'3FFF'
    _WDT_OFF                     EQU     H'3FFB'
    _EXTCLK			     EQU     H'3FEF'
    _HS_OSC                      EQU     H'3FEE'
    _XT_OSC                      EQU     H'3FED'
    _LP_OSC                      EQU     H'3FEC'
    ;Configuration Byte 2 Options
    _IESO_ON                     EQU     H'3FFF'
    _IESO_OFF                    EQU     H'3FFD'
    _FCMEN_ON                    EQU     H'3FFF'
    _FCMEN_OFF                   EQU     H'3FFE'
    ; To use the Configuration Bits, place the following lines in your source code
    ;  in the following format, and change the configuration value to the desired
    ;  setting (such as CP_OFF to CP_ALL).  These are currently commented out here
    ;  and each __CONFIG line should have the preceding semicolon removed when
    ;  pasted into your source code.
    ;Program Configuration Register 1
    ;		__CONFIG    _CONFIG1, _CP_OFF & _CCP1_RB0 & _DEBUG_OFF & _WRT_PROTECT_OFF & _CPD_OFF & _LVP_OFF
    & _BODEN_OFF & _MCLR_OFF & _PWRTE_OFF & _WDT_OFF & _HS_OSC
    ;Program Configuration Register 2
    ;		__CONFIG    _CONFIG2, _IESO_OFF & _FCMEN_OFF
            LIST
    That is the inc file from MPASM, do not modify it. That is where you get info about the chip.
    The inc file you modify is in the PBP directory. It looks like this.
           NOLIST
        ifdef PM_USED
            LIST
            include 'M16F88.INC'	; PM header
     ;       device  pic16F88, hs_osc, wdt_on, lvp_off, protect_off
            XALL
            NOLIST
            LIST
            LIST p = 16F88, r = dec, w = -302
            INCLUDE "P16F88.INC"	; MPASM  Header
      ;      __config _CONFIG1,_INTRC_IO& _WDT_ON & _LVP_OFF & _CP_OFF
            NOLIST
            LIST
    Notice the ';' That is a comment for this type of file. The two lines between LIST and LIST with comments are the lines to change or if setting the fuses in code space comment out.
    Dec 2007
    Unhappy
    Thanks for your patience Dave!
    Well, I commented out the two lines as you suggested recompiled and put the code into the PIC and it froze! Tried a few times and also tried to reset the PIC but noting, stone cold! I opened the inc file, restored it, recompiled the code and it was all back to normal.
    I must have my stupid hat on this week, this thing just won’t fly!
    If you ser the fuses in code space then comment the two lines. Otherwise do like you are in the inc file.
    Personally I like to set up in the inc.
    Does it work at all now?
    Dec 2007
    Question
    I commented out the two lines in the inc file and added the ” @__config _CONFIG1,_INTRC_IO& _WDT_ON & _LVP_OFF & _CP_OFF” to the code right below the “@__config_INTRC_IO” line but it refuses to compile! I get “[235] opcode expected instead of ‘_hs_osc’” error! ?
    If I remove the line it compiles and everything except RA6 & RA7 I/O run perfect as before.
    I am confused to say the least!
    Thanks for the support!
    Have you tried this thread yet? And I do mean the whole thing, not just the first and/or last post, but everything in between, everything linked, and then try everything in there to get a feel for how everything works?
    Not that you'll ever need to use everything in there, but down the road, something in this thread might come up and you'll have that knowledge in the back of your head ready to go...and it'll save you loads of time...then...
    I have an idea. Copy this code exactly and tell us if RA6 and RA7 ports flash an LED. Put about 100 ohms on 1 side of the LED. I just tried it with a 16F88 and it works for me.
    ANSEL = 0 'ALL DIGITAL
    TRISA = %00000000 'ALL OUTPUTS
    TRISB = %00000000 'ALL OUTPUTS
    PORTA = 0 'PORTA LOW
    Pause 100 'SETTLE DOWN
    START:
    High PORTA.6 'ON LED
    High PORTA.7
    Pause 1000
    Low PORTA.6 'OFF LED
    Low PORTA.7
    Pause 1000
    GoTo START 'REPEAT FOREVER
    One question is left unanswered though...is this with or without a modified 16f88.INC file?
    And I'm not sure if an LED will flash with +5v on both sides and ground on both sides
    Sorry if I wasn't clear. It works for me without a modified inc file. And the LED's connect from the port pins to ground. Now come on. You knew that didn't you Skimask?
    Thumbs up
    Yep, just quietly pointing out a few 'options'!
    Mar 2006
    Smile Config bits
    If using MPASM use this!!! Use both config!!!
    ; __CONFIG _CONFIG1, _CP_OFF & _CCP1_RB0 & _DEBUG_OFF & _WRT_PROTECT_OFF & _CPD_OFF & _LVP_OFF & _BODEN_OFF & _MCLR_OFF & _PWRTE_OFF & _WDT_OFF & _HS_OSC
    Mar 2006
    Smile Config bits
    ;* 16F88.INC *
    ;* By : Leonard Zerman, Jeff Schmoyer *
    ;* Notice : Copyright (c) 2004 microEngineering Labs, Inc. *
    ;* All Rights Reserved *
    ;* Date : 01/07/04 *
    ;* Version : 2.45 *
    ;* Notes : *
    don't forget to comment out the following in the 16F88.INC file
    NOLIST
    ifdef PM_USED
    LIST
    XALL
    NOLIST
    LIST
    ; __config _CONFIG1, _HS_OSC & _WDT_ON & _LVP_OFF & _CP_OFF
    NOLIST
    LIST
    Dec 2007
    Smile
    Thanks guys,
    Just returned from my vacation!
    >leisryan: I tried your suggestion but I get two warnings compiling and the PIC hangs if I program it despite the warnings.
    Is there no possible way to set the CONFIG1 (FOSC) bit 4, 1 and 0 to (%1XX00) in the code without disturbing other settings?
    Thank you!
    You're asking the exact same question as in the original post and you have been given the answers you need to figure out how to do what you want to do.
    Just as described in the link in post #19. It will cure almost 99.99999999999999999999% of your (and anybody else's) CONFIG fuse woes...if you read and comprehend the text of the post.
    Hi PICante,
    Lots of speculation going on here, please give this a try:
    @ __config _CONFIG1,_INTRC_IO
    OSCCON =126 ' or 1111110 or $7E for 8mhz, 1101110 for 4mhz, 1011110 for 2 mhz . . .
    page 40 of the data sheet I am looking at, sect. 4.6.3
    Osccon bits 6:4 set osc speed, bit 3 when set makes primary clock, bit 2 set= stable, not set= not stable, bit 1:0 set as 10 = internal R/C as system clock<br>
    edit: 1111110 = 126 not 62
    Dec 2007
    Thanks skimask, I have read through what you suggested and all the links and I am sorry to say it did not get me anywhere. I tried a few things without really knowing what I was doing and none of it worked. Most of it was about the PIC18F family which is (in my view) much more advanced compared to the 16F88 which I am trying to figure out. I mean I have to learn to crawl before I can run. Reading stuff that reefer to things way beyond where my knowledge are at this point just messes up my head. I understand that looking from your level of knowledge this might look ridiculous.
    Joe S. > Thank you, I will try it this evening and let you know.
    Nope, not ridiculous at all, not even close. It's a common question, all too common. Somehow I think Microchip should have come up with a better way to do the CONFIG fuses in the first place. But the information in that link is the key... When you figure all that out, a lot of other things PIC related come into focus...
    Mar 2006
    Cool Try this!!!
    It's a complete project i built it for my 12v security camera multiple dc ouput 9 event daily timer!!! Don't worry we used to bite our nails before believe me I too ridicule myself before without knowing it..... hope this helps you use mpasm as compiler in "view" tab then in compiler options.........project no.5 is complete
    Mar 2006
    Smile
    if you still can't make it work review post no. 35 bro!!! goodluck!!!
    Dec 2007
    Smile
    Thank you very much Joe!
    Now it works the way it should!
    I will now try to backtrack through the datasheet WHY it works and hopefully learn from it!
    Thanks again to all of you! :-)
    Din framgång er på min ålder framgång! Många fisk i den här Datan Ark.
    Dec 2007
    Talking
    Hi Joe,
    I recognize the words but not the composition! It says something like this:
    “Your success you on my age success! Many fish in that here computer ark.”
    Hi Joe,
    So online translators are that good It was supposed to say . . . Your success is my success, and there are many fish in those data sheets which is supposed to relate to my signature of learning to fish. Glad you are on track with your project, I got to learn from it too, thanks.
  1. PICKit2 - warning about configuration words
    Last Post: - 4th August 2009, 15:01
  2. Setting I/O ports on 16f629
    By Optech in forum mel PIC BASIC Pro
    Last Post: - 24th January 2008, 22:51
  3. 16F88 RA6 and RA7 troubles
    By gandora in forum mel PIC BASIC Pro
    Last Post: - 3rd August 2007, 03:57
  4. 16F88 - CCPMX strange fuse setting for HWPM
    Last Post: - 5th April 2007, 23:33
  5. Making RA6 (OSC2) an output on a 18F2525
    Last Post: - 28th September 2006, 18:51
