12F629 Won't SLEEP
Results 1 to 8 of 8
    Default 12F629 Won't SLEEP
    I can't get this PIC to SLEEP with the following program:
    CMCON = %00000111
    TRISIO = %001100
    OPTION_REG = %01000000
    PIR1 = 0
    GPIO = 0
    @ DEVICE MCLR_OFF, INTRC_OSC, WDT_OFF, BOD_OFF, PWRT_OFF, PROTECT_OFF
    'GPIO.0 =
    'GPIO.1 = LED HIGH OUT
    'GPIO.2 = SWITCH HIGH INPUT
    'GPIO.3 = MCLR TIED HIGH
    'GPIO.4 =
    'GPIO.5 =
    GPIO.1 = 1
    PAUSE 100
    INTCON = %00000000
    FLAGS = 0
    @SLEEP
    GPIO.1 = 0
    The LED goes on briefly, and then turns off. If it really does go to SLEEP, then something is waking it up. Help please!
    Nevermind! GPIO.2 was tied high due to a wiring error. Datasheet says this will interrupt SLEEP, regardless of INTCON settings. Works O.K. now.
    O.K., I give up. The name of this thread should be 12f629 wakes up unexpectedly. Here is the latest code:
    CMCON = %00000111
    TRISIO = %001100
    OPTION_REG = %10000000
    PIR1 = 0
    GPIO = $000000
    @ DEVICE MCLR_OFF, INTRC_OSC, WDT_OFF, BOD_OFF, PWRT_ON, PROTECT_OFF
    'GPIO.0 =
    'GPIO.4 =
    'GPIO.5 =
    GPIO.1 = 1
    PAUSE 100
    INTCON = %00000000
    FLAGS = 0
    @SLEEP
    NOP
    GPIO.1 = 0
    I have checked all pins with a scope, added decoupling capacitors on the +5 volt and MCLR pins, and the result is always the same. If the last line of the program is present, the LED goes out. So clearly something is causing the PIC to wakeup. What am I missing?
    Is my problem so stupid that no one will give me suggestions? I believe I have read everything, and tried many things. Please help. Thank you.
    Put a space between @ and SLEEP.
    Edit: I guess this bears a little more detail. What happens is by placing @SLEEP in
    there it doesn't generate code for SLEEP, so you land on the next valid instruction
    which would be your GPIO.1 = 0.
    You don't have the @ symbol before your NOP either, so PBP creates a lable instead
    of code for the NOP. @ NOP would be the correct way to insert an assembly NOP
    instruction.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Quote Originally Posted by jderson View Post
    Might just be only BRUCE saw the problem.
    Thank you Bruce and Joe! The space solved the problem. Staring me in the face all along!
    well, that explains why i couldn't get a pic to sleep either. lol
  1. Won't go back to SLEEP after 1st Interrupt
    Last Post: - 29th June 2009, 10:00
  2. sleep on 12f629
    By sirvo in forum mel PIC BASIC Pro
    Last Post: - 8th February 2007, 15:08
  3. 16F628A current high during sleep
    Last Post: - 9th October 2006, 11:21
  4. Wierd sleep issue
    By orca in forum mel PIC BASIC Pro
    Last Post: - 14th March 2006, 23:06
  5. Programming 12F629 low power (Sleep)
    By Warrier in forum mel PIC BASIC Pro
    Last Post: - 29th November 2004, 15:45
