Structure of a Byte Variable
Results 1 to 2 of 2
    Default Structure of a Byte Variable
    Thanks to the code posted below by Darrel
    in http://www.picbasic.co.uk/forum/showthread.php?t=9134
    TimeCmpFlags  VAR BYTE
      PastStart   VAR TimeCmpFlags.0
      PastStop    VAR TimeCmpFlags.1
      NextDay     VAR TimeCmpFlags.2
      ProgON      VAR TimeCmpFlags.3
    CheckTimes:
      TimeCmpFlags = 0  ; clear flags first
         ; if the Start and Stop times are the same, then Always OFF
      if (Stop_H=Start_H) AND _
         (Stop_M=Start_M) AND _
         (Stop_S=Start_S) then AlwaysOFF
         ; is it past the Start time?
      if (Hours>Start_H) OR _
         (Hours=Start_H AND Minutes>Start_M) OR _
         (Hours=Start_H AND Minutes=Start_M AND Seconds>=Start_S) then PastStart=1
         ; is it past the Stop time?
      if (Hours>Stop_H) OR _
         (Hours=Stop_H AND Minutes>Stop_M) OR _
         (Hours=Stop_H AND Minutes=Stop_M AND Seconds>=Stop_S) then PastStop=1
         ; does the period end the following day?
      if (Stop_H< Start_H) OR _
         (Stop_H=Start_H AND Stop_M < Start_M) OR _
         (Stop_H=Start_H AND Stop_M=Start_M AND Stop_S < Start_S) then NextDay=1
      if !NextDay then                               ; same day, use AND
          if PastStart AND !PastStop then ProgON = 1
      else                                           ; next day, use OR
          IF PastStart OR !PastStop then ProgON = 1
      AlwaysOFF:
    I will never think of a BYTE variable the same way again. I always thought of a BYTE as a container which holds a number from 0-255, but the code above struck me this way, a BYTE is a BIT Array! where 8 bits all share the same variable name. All in how you look at things I guess, I saved this as an example for some future need. Thanks Darrel.
    Exactly!
    Thanks for fishing Joe.
  1. LCD freeze
    By harryweb in forum mel PIC BASIC Pro
    Last Post: - 5th October 2009, 08:01
  2. Memory use - how much do you use?
    By keymuu in forum mel PIC BASIC Pro
    Last Post: - 10th June 2009, 22:39
  3. byte compression
    By Norbert in forum mel PIC BASIC Pro
    Last Post: - 16th June 2007, 18:04
  5. 16F877 RAM Question
    By Art in forum mel PIC BASIC Pro
    Last Post: - 6th August 2005, 11:47
