interupt & Sleep Problem - HELP!!
Results 1 to 4 of 4
    Santana's Avatar
    Santana Guest
    Question interupt & Sleep Problem - HELP!!
    Hello People
    I have a problem i have being trying toget my head round over the past 4 nights andhave come up with no solution so your help would be very much appreciated.
    THE Design
    i am designing a data logger around the PIC18F452 as i would need 3 interupt sources
    1. RB0 To wakeup the pic then take a reading
    2. RB1 To wakeup the pic then take and take user setting( ie
    Reading interval etc)
    3. RB2 To be used as countdown timer using the 1Hz output
    from a DS1307 RTC
    THE Problem
    My PIC is asleep at least 99% of time , but RB2 interupt wakes it up when the 1hz pulse is applied
    Is there another way i can count the pulses from the RTC without waking the PIC Or is there another way i can do this without using interupt on RB2?
    The first two interupts works perfectly but i need to include a countdown timer so that i can check when 12 months has elasped
    Please Help as i am slowly runningout of time
    Best Regards
    Post
    You could use Timer1(or 3) configured as a counter and count the external 1Hz pulses. This way you could count pulses for up to six days without waking the pic. If you configure the counter with a prescaler 1:8 and preset it with 11536(65536-54000) you will count 8*54000=432000secs, that's exactly 5 days. When you have had this interrupt 73 times, exactly one year(365days) have passed.
    /Ingvar
    Santana's Avatar
    Santana Guest
    Thanks Ingvar
    Thats a good idea have you got any example on how tp set this up
    Post
    I haven't used this pic before but i can't see any major difficulties in setting it up. You already seem to be able to start and service interrups so i won't deal with that. Initialize the timer with ....
    TMR1L = $10
    TMR1H = $2D 'Start timer with 65536-54000=11536
    T1CON = %00110111
    ' here you should input code to enable the interrupt
    ..... in your ISR you should reset the timer to $2D10 again, increment your fivedaycounter and reset the interruptflag.
    Perhaps it would be easier if you posted your code and i'll make the changes that are needed.
    /Ingvar
  1. sleep problem help plz >>>.
    By Mus.me in forum mel PIC BASIC Pro
    Last Post: - 16th November 2009, 09:21
  2. Won't go back to SLEEP after 1st Interrupt
    Last Post: - 29th June 2009, 10:00
  3. UP/down counter & shiftout interupt problem
    Last Post: - 2nd July 2007, 16:56
  4. 16F628A current high during sleep
    Last Post: - 9th October 2006, 11:21
  5. Wierd sleep issue
    By orca in forum mel PIC BASIC Pro
    Last Post: - 14th March 2006, 23:06
