Definitive MPLAB Config Examples
Results 1 to 4 of 4
    Hi Brian,
    I wouldn't be really concerned about using the new 18F config directive unless just want
    to modifiy your existing PBP header files to be compatible with the latest changes.
    Note: This may change by next week the way Microchip works..;o}
    If you're referring to this thread: http://www.picbasic.co.uk/forum/show...3087#post13087
    it should be OSCS=OFF VS OSCS_OFF. The new config directive does not support the
    underscore character.
    As to whether or not this particular config fuse option is even available for the PIC in
    question, follow Skis' advice and look in the default Microchip device header file. This
    shows every config option available for the target PIC. Of course, you'll also want to
    take a peek at the datasheet for the PIC in question. They don't all have the same
    config fuse options.
    If your case, for the 18F4620, it does not appear that the controller has the option for
    OSCS=OFF (which would be the Osc Switch Enable) as, say, you would have for an 18F452.
    The Microchip device .INC header files give a very descriptive list of what each config fuse
    option does. The data sheet goes into much greater detail.
    Here's a short clip from the P18F452.INC file;
    ; Osc. Switch Enable:
    ; OSCS = ON Enabled
    ; OSCS = OFF Disabled
    ; Power-up Timer:
    ; PWRT = ON Enabled
    ; PWRT = OFF Disabled
    ; Brown-out Reset:
    ; BOR = OFF Disabled
    ; BOR = ON Enabled
    These are config fuse options you can use with the new config directive for the 18F452.
    Now look in the P18F4620.INC file in your MPLAB installation directory for a list of config fuse
    options that are available for this target.
    NOTE: You cannot (at least for now) use the new config directives directly in your PBP code.
    PBP will not allow these to be inserted directly in your code. You'll need to modify the default
    18F4620.INC file in your PBP directory.
    That's why you don't see the @ symbol before the config fuse directive in my example at
    the link above.This is only required when you insert the (old config directives) directly into
    your PBP code (and you have the others commented out) as shown below. It's not required
    when you do this in the PBP .INC file.
    Here's an example of my own modified 18F2431.INC file in my PBP directory.
    LIST
            LIST p = 18F2431, r = dec, w = -311, w = -230, f = inhx32
            INCLUDE "C:\Program Files\Microchip\MPASM Suite\P18F2431.INC"  ; MPASM  Header
    	CONFIG OSC=XT,FCMEN=OFF,IESO=OFF,PWRTEN=ON,BOREN=ON,BORV=27
    	CONFIG WDTEN=OFF,WINEN=OFF,WDPS=128,T1OSCMX=OFF,MCLRE=OFF
    	CONFIG LVP=OFF,STVREN=OFF
            ;__CONFIG    _CONFIG1H, _OSC_IRCIO_1H ; _OSC_XT_1H
            ;__CONFIG    _CONFIG2H, _WDTEN_OFF_2H & _WDPS_512_2H
            ;__CONFIG    _CONFIG4L, _LVP_OFF_4L
            NOLIST
    I use an old Windows ME OS, so I have to point directly to my MPASM suite directory, and
    I've changed to the new config directive. I can't directly insert the new config directive in
    my PBP code. It just doesn't work.
    I can, however, alter my default PBP 18F2431.INC file to use these.
    Yeah, I know, it seems confusing, but it's worth the extra effort to learn this.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Default Definitive MPLAB Config Examples
    Thanks folks.
    My understanding is as follows:
    1. PBP does not directly support the new CONFIG directive.
    2. The old style @ __CONFIG still works within the PBP code.
    3. The line continuation character for in line assembly is the same as for PBP i.e. "_".
    4. I can edit the .inc file and use the new CONFIG and its new, clearer parameters there.
    Maybe I didn't chicken out after all! If editing the .inc is good enough for Bruce, it's good enough for me.
    Just noticed that the HS oscillator option for an 18F452 is _HS_OSC_1H and for an 18F4620 it has been handily transposed to _OSC_HS_1H. What fun what fun!
    Thanks again,
    Brian Walsh.
  1. A/D conversion with PIC18F67J50
    By ScaleRobotics in forum mel PIC BASIC Pro
    Last Post: - 8th May 2009, 02:48
  2. 18F4550 Bootloader enter via eeprom setting
    By bradb in forum mel PIC BASIC Pro
    Last Post: - 23rd November 2008, 00:51
  3. Error 0X0000008E when connecting a 18F2550 USB HID
    By FranciscoMartin in forum USB
    Last Post: - 16th October 2008, 18:20
  4. PortE problems (PIC18F4455)
    By RubenR in forum mel PIC BASIC Pro
    Last Post: - 12th July 2006, 16:26
  5. Installation sequence
    By Demon in forum General
    Last Post: - 11th July 2006, 04:56
