PWM: Vernacular/Function (Newbee)
Results 1 to 3 of 3
    Sep 2005
    Campbell, CA
    You should decide whether or not a PWM frequency of 32,767Hz is fast enough for your application. That is the highest PWM frequency you can get with the PBP command "HWPWM" regardless of your oscillator frequency. If you need a PWM frequency higher than 32Khz, you need to write CCP1CON[4:5] and CCPR1L directly. You can get a PWM frequency of several hundred kilohertz that way - depending on your oscillator frequency and the number of bits of resolution you need.
    HWPWM is not "bit banging". Bit banging usually involves sitting in a tight loop running software counters to do the PWM function - the PIC can't do anything else at that same time. HWPWM on the other hand, sets up the hardware to produce a PWM signal and your main program can go merrily on its way.
    A third possible alternative is to use Darrel Taylor's PWM routine. It uses interrupts and counters to perform software (or bit-banging) PWM. The highest PWM frequency isn't very high, but this method can give you lots of channels of PWM without using 100% of your processor.
    Charles Linquist
    Jul 2008
    Default Thanks
    Very helpful post, Thank You.
  1. Half-bridge PWM with a 16F684 ?
    Last Post: - 17th January 2010, 23:18
  2. Variable PWM PIC18F2431
    By trr1985 in forum mel PIC BASIC Pro
    Last Post: - 12th June 2009, 07:03
  3. PWM setting PIC16F887
    By Gevo in forum mel PIC BASIC Pro
    Last Post: - 12th June 2008, 08:24
  4. Newbee Hardware PWM clarification needed
    By emmett brown in forum General
    Last Post: - 9th July 2006, 10:18
  5. Tidying Up PWM Routine
    Last Post: - 21st February 2005, 01:26
