How do I format HSERIN?
Results 1 to 20 of 20
    May 2007
    Suffolk, UK
    Hi Skimask
    Thanks but there is something I'm not understanding. I've tried your programme and it works fine until the first timeout then it won't 'goto main' and loop through again. Should it? If I change the counter to FOR temp = 0 to 7 then the programme loops round endlessly. What am I not understanding or what am I doing wrong? Please help - going mad here!!
    Adrian
    Might get a couple of hints from this:
    http://www.picbasic.co.uk/forum/show...ht=hserin+idle
    If not there, then try a search on serial and idle and see what happens.
    Mar 2004
    UK-Midlands
    I usually refer back to this sample program if I forget how to use a modifier;
    http://www.melabs.com/resources/samples.htm
    and load the sample program ser2mod.bas
    Bob
    May 2007
    Suffolk, UK
    Thanks for that Bob. The bit I was confused about is Skimask's statement "MyVars var Byte[8] sets aside 9 bytes, index 0 (zero) is also valid"
    I thought I understood that MyVars VAR BYTE[8] had 8 elements numbered 0 to 7 (Page 26 PBP new manual). If that were the case then the 'clearance' counter ought surely to be 0 to 7 not 0 to 8, which would be invalid.
    Adrian
    Quote Originally Posted by Adrian View Post
    Adrian
    Ya know...you're right. I've been reading that line in the manual 'bass-ackward' all this time. Never had a problem with it, but still.........
    May 2007
    Suffolk, UK
    Thank you for that, Skimask. I really appreciate you coming back and putting this one to bed once and for all. I guess that Counter 0 to 7 clears the temp array and 0 to 8 hangs up due to the extra 'rogue' index.
    I really do appreciate your input and have learned some more about this interesting and all absorbing science
    Regards & thanks
    Adrian
  1. TMR0 interrupt and HSERIN
    By boban in forum mel PIC BASIC Pro
    Last Post: - 2nd September 2008, 11:48
  2. Serout format
    By aftab in forum mel PIC BASIC Pro
    Last Post: - 22nd August 2007, 07:12
  3. 16F877a Interupt driven Hserin
    Last Post: - 3rd November 2006, 00:38
  4. Can a TMR interrupt stops HSERIN?
    By SergioRM in forum mel PIC BASIC Pro
    Last Post: - 24th January 2006, 01:07
  5. Hserin
    By egberttheone in forum mel PIC BASIC Pro
    Last Post: - 27th November 2004, 15:42
