How do I format HSERIN?
Results 1 to 20 of 20
    I think he meant ...
    See HSERIN in the PBP manual. Look at the STR modifier.
    Jul 2008
    Wyoming, US
    Default HSERIN syntax frustration
    Being a beginner myself I have the same problem with getting simple commands and mondifiers to function. I'm looking in the PBP manual at the STR Modifier and they just don't give any examples on how to use it. I'm also interested in the use of this function as I would like to be able to send commands to the PIC and dinamicly update it.
    Yep, that's what I meant...
    der.....
    MyVars VAR BYTE(8)
    HSERIN 500,NoData,[STR MyVars\8\"~"]
    NoData:
    do something else
    This will wait 500mS before jumping to NoData. It will receive a string of up to 8 characters
    in byte array MyVars, or exit on receipt of the "~" character.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Mar 2008
    Default Still can't get HSERIN to receive data correctly
    From a PC I send 123:CRLF as 495051581310
    When I try:
    MyVars VAR BYTE(8)
    HSERIN 500,NoData,[STR MyVars\6\":"]
    NoData:
    HSEROUT ["Timeout",$0d,$0a]
    Goto main
    It always goes to NoData. I never get anything into MyVars.
    If I use HSERIN 500,NoData,[STR MyVars\1\":"] I get random data. It is different each time I send the data.
    What am I missing?
    Bob Hiller
    Lifts for the Disabled LLC
    Have you tried increasing the timeout period?
    P.S. How do you know what you're receiving? Your example doesn't show how you're
    checking what's received!
    -Bruce
    tech at rentron.com
    Don't send 123:CRLF as 495051581310....send it as 123:<CR> with line feeds turned on at the PC.
    HSERIN doesn't need to use raw hex codes for the data (i.e. sending 10 for a line feed, etc).
    Are you using the internal oscillator on the PIC?
    The internal oscillator isn't always accurate. Could cause your baud rate to be off by just enough to confuse everything.
    Are you using a MAX232 type device between the PIC and the PC?
    The hardware UART uses 'TTL-RS232', commonly called 'Normal' in PBP circles. Try using SERIN2/SEROUT2 and using an inverted mode if you don't have a MAX232.
    Are you sure the PIC is configured correctly for the desired baud rate?
    Can get a bit confusing with all of the options a PIC has. Double check them...
    Are you sure the config registers/any other registers are set up correctly?
    Internal vs. External crystals...and so on and so on...
    Mar 2008
    I am using MAX32 between the PC and PIC.
    HSEROUT works every time no matter what I send. Thank makes me assume that the BAUD issue is OK.
    Here is how I check what I am receiving:
    HSEROUT ["B1 ", MyVars(0), $0d,$0a]
    HSEROUT ["B2 ", MyVars(1), $0d,$0a]
    HSEROUT ["B3 ", MyVars(2), $0d,$0a]
    HSEROUT ["B4 ", MyVars(3), $0d,$0a]
    HSEROUT ["B5 ", MyVars(4), $0d,$0a]
    etc..
    Quote Originally Posted by PlantBob View Post
    Ok, just checking, didn't have that info before.
    Like I said before, don't send the raw hex data back and forth, just send the characters themselves.
    MyVars VAR BYTE[8] : temp var byte
    Main: HSERIN 5000,NoData,[STR MyVars\6\":"]
    HSEROUT ["Received:", STR myvars\8",13,10] : goto main
    NoData: HSEROUT ["Timeout",$0d,$0a]
    for temp = 0 to 8 : myvars[temp]=0 : next temp 'clean out myvars
    Goto main
    At the PC, type in a few characters (no hex codes, nothing crazy, just a few alpha or number characters), followed by the : character.
    The code above should wait for 5 seconds to 1)get no data, 2) get 6 bytes of data, or 3)will kick out and send back the data you just sent if you sent a : before you sent a total of 6 bytes.
  1. TMR0 interrupt and HSERIN
    By boban in forum mel PIC BASIC Pro
    Last Post: - 2nd September 2008, 11:48
  2. Serout format
    By aftab in forum mel PIC BASIC Pro
    Last Post: - 22nd August 2007, 07:12
  3. 16F877a Interupt driven Hserin
    Last Post: - 3rd November 2006, 00:38
  4. Can a TMR interrupt stops HSERIN?
    By SergioRM in forum mel PIC BASIC Pro
    Last Post: - 24th January 2006, 01:07
  5. Hserin
    By egberttheone in forum mel PIC BASIC Pro
    Last Post: - 27th November 2004, 15:42
