How do I format HSERIN?
Results 1 to 20 of 20
    Mar 2008
    Default How do I format HSERIN?
    I am using a 16f688 and I use HSEROUT with no problems. I now need to send some data back to the 16f688. How do I format the HSERIN command if I don't know how much data is coming?
    Bob Hiller
    Lifts for the Disabled LLC
    Quote Originally Posted by PlantBob View Post
    HSEROUT has provisions for an 'ending' character. You can fill an array of bytes up to said 'end' character. See HSEROUT in the PBP manual. Look at the STR modifier.
    Mar 2008
    I see no reference to filling an array and waiting for termination characters in the PBP manual. Do you have a sample?
    Bob Hiller
    I think he meant ...
    See HSERIN in the PBP manual. Look at the STR modifier.
    Jul 2008
    Wyoming, US
    Default HSERIN syntax frustration
    Being a beginner myself I have the same problem with getting simple commands and mondifiers to function. I'm looking in the PBP manual at the STR Modifier and they just don't give any examples on how to use it. I'm also interested in the use of this function as I would like to be able to send commands to the PIC and dinamicly update it.
    Yep, that's what I meant...
    der.....
    MyVars VAR BYTE(8)
    HSERIN 500,NoData,[STR MyVars\8\"~"]
    NoData:
    do something else
    This will wait 500mS before jumping to NoData. It will receive a string of up to 8 characters
    in byte array MyVars, or exit on receipt of the "~" character.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
  1. TMR0 interrupt and HSERIN
    By boban in forum mel PIC BASIC Pro
    Last Post: - 2nd September 2008, 11:48
  2. Serout format
    By aftab in forum mel PIC BASIC Pro
    Last Post: - 22nd August 2007, 07:12
  3. 16F877a Interupt driven Hserin
    Last Post: - 3rd November 2006, 00:38
  4. Can a TMR interrupt stops HSERIN?
    By SergioRM in forum mel PIC BASIC Pro
    Last Post: - 24th January 2006, 01:07
  5. Hserin
    By egberttheone in forum mel PIC BASIC Pro
    Last Post: - 27th November 2004, 15:42
