GPS clock timing !
Results 1 to 12 of 12
    Quote Originally Posted by bethr View Post
    It's alive !!
    WooHoo!
    I'm wondered why this bit must be set in hi speed if my bps is low ! (4800 bps)
    With a 4mhz OSC, I wouldn't consider 4800 "low".
    In the datasheet there's a couple tables that show the baud rates vs. OSC freq with BRGH either 1 or 0. With BRGH=0 @ 4mhz, the highest baudrate in the table is 2400. With BRGH=1 it's 19200.
    It may still work with BRGH=0, but it's close to the edge, so why not just make it BRGH=1.
    I think the HSER_CLROERR 1 may have had the biggest effect.
    The GPS will just spit out the data at regular intervals. It doesn't wait for the PIC to be ready. And at 4800 baud it can send a byte every 2ms. So when the program sits in a 500 ms pause, it may receive a couple hundred bytes before the program gets around to looking at the data. There's only a 2 byte buffer in the USART so it causes an Overflow that must be cleared before it will start receiving data again.
    BTW currently I'm not using UART interrupts, but . . .
    . . . what if . . .
    I enable it ?, this give more reliable data incoming form the GPS line ? or it can be dangerous for the RTC health ?
    HSERIN is not compatible with USART interrupts.
    You would need to parse the incomming data 1 byte at a time with your own handlers.
    It's much easier to use HSERIN.
    hth,
    Jul 2006
    Talking
    Yes you're Right, I think that on this way the gps clock work well, there is no problem with it, I have it running & all looks nice !
    The program doesn't anything important (just led blinking), and when BTN rb0 is pushed, it gets info from GPS module and update my RTC registers just as i wanted !
    'BETHR
    '''''''''''''' INCLUDES ''''''''''''''''''''''''''''''''''''
    	INCLUDE "DT_INTS-18.bas"
    	INCLUDE "ReEnterPBP-18.bas"
    	INCLUDE "Elapsed_INT-18.bas"
    	INCLUDE "LCDPICDEM2.BAS"		' it runs on PIDEM2 PLUS Board
    	DEFINE HSER_TXSTA 24h 			' BRGH=1
    	DEFINE HSER_RCSTA 90h
            DEFINE HSER_CLROERR 1 			' Hser clear overflow automatically
    	DEFINE HSER_SPBRG 51
    ''''''''''''' VARS ''''''''''''''''''''''''''''''''''''
    		led   var Portb.2
    		timeh var byte
    		timem var byte
    		times var byte
    		day	  var byte
    		mon   var byte
    		yr    var byte
    		stat  var byte
    		gps   var Portb.1
    		TRISB.2 = 0
    		TRISB.0 = 1
        	         Adcon1 = $07
    init:
    	        INT_Handler   TMR1_INT,  _ClockCount,   PBP,  yes
    	INT_CREATE
    	@    INT_ENABLE  TMR1_INT
    	Gosub ResetTime
    	Gosub StartTimer
    	hours = 12 'after reset we always star @12:00:00
    Start:
    	lcdout $fe,1,"GPS Clock "
        Pause 500
    	While 1
    'do something [  something more useful than this :-)  ]
    		While (portb.0=1)
    			Toggle led
    			Lcdout $fe,2,"Date : ",dec2 day,47,dec2 mon,47,dec2 yr
    			Lcdout $fe,$c0,"Time : ",dec2 hours,":",dec2 minutes,":",dec2 seconds
    		 	Pause 200
    		Wend
    ' if i press rb0 btn update my RTC
    		Gosub Update_rtc
    	Wend
    ''' SUBS ''''
    Update_rtc:
    'look 4 stream
    	lcdout $fe,1,"Updating..."
    	Hserin 500,no_gps,[WAIT("MC,"),dec2 TIMEH,dec2 TIMEM,dec2 TIMES,SKIP 5,_
    	STAT,skip 30,dec2 day,dec2 mon,dec2 yr]
    'check 4 Valid GPS if so, then update my RTC
    	if stat = "A" then
    		hours=timeh - 5 : minutes = timem: seconds = times
    'no gps so don't update
    		lcdout $fe,1,"Bad Fix" : pause 500
    'np gps or bad sintax
    no_gps:
    	lcdout $fe,1,"No Gps stream" : pause 500
    ''' END SUBS ''''
    I've had to replace my broken LCD also !!
    BIG TNX !
    Jan 2007
    Houston, TX
    Default GPS info
    Hi there Bethr,
    I am looking at purchasing a garmin LVS gps for a robot project and I was just wondering what kind of gps you are using? Cost? etc....
    Padawan-78
    Quote Originally Posted by earltyso View Post
    Hi there Bethr,
    If it has an NMEA serial output line, then you can get usable data out of it.
    www.sparkfun.com has a few GPS modules already mounted, ready to use.
    Jul 2006
    Hi there Bethr,
    currently I have two modules
    this:
    http://www.trimble.com/embeddedsyste...?dtID=overview
    and this one , a low profile asian embedded device:
    both were removed from used equipment, but I know that the trimble module have a cost near to 50 usd (versus qty)
    and the other one near to 30 usd
    both devices has NMEA ascii output @t vdd levels, trimble vdd=3v3 and asian device vdd=5v
    Cheers !!
  1. GPS $GPRMC to PIC16F684. Need help with SERIN2
    Last Post: - 27th November 2009, 09:47
  2. Shiftout/in
    By BobEdge in forum mel PIC BASIC Pro
    Last Post: - 23rd August 2007, 11:48
  3. Help with sound command in 2 programs
    Last Post: - 5th July 2007, 20:36
  4. Replies: 2
    Last Post: - 28th April 2006, 12:10
  5. GPS Receiver
    By lester in forum Adverts
    Last Post: - 22nd February 2006, 12:47
