GPS clock timing !
Results 1 to 12 of 12
    Jul 2006
    Default GPS clock timing !
    Dear Forum:
    I'd like to build a small Clock with GPS time-sync, look, I'm using the Darrel instant interrups to drive the Timer 1 clock, it works great ! (Thanks Darrel !), but when I tried to read the GPS data (over Pin RB1) there is a lot of missed/corrupted bytes in my buffer, something like this:
    the first lcd line is the RMC message data (corrupted in this case) and the second line display the RTC registers, (plese note tha my LCD was broken so the lower line is wrong )
    this is the code
    '''''''''''''' INCLUDES ''''''''''''''''''''''''''''''''''''
    	INCLUDE "DT_INTS-18.bas"
    	INCLUDE "ReEnterPBP-18.bas"
    	INCLUDE "Elapsed_INT-18.bas"
    	INCLUDE "LCDPICDEM2.BAS"		' it runs on PIDEM2 PLUS Board
    ''''''''''''' VARIABLES ''''''''''''''''''''''''''''''''''''
    		j    var byte
    		rmc  var byte[100]	' this gets RMC data
    		led1 var  portb.2
    		b0   var byte
    		adcon1 =$07
    		trisa.2 = 0
    		trisa.4 = 1
    		trisb.1 = 1
    		trisb.2 = 0
    		trisb.0 = 1
    		trisc.2 = 0
    	    porta.2 = 0
    		gps var portb.1
    	 	spk    var portc.2
    ''''''''''''' CODE ''''''''''''''''''''''''''''''''''''
    init:
    	        INT_Handler   TMR1_INT,  _ClockCount,   PBP,  yes
    	INT_CREATE
    	T0CON = %10011010
    	@    INT_ENABLE  TMR1_INT
    	GOSUB ResetTime
    	GOSUB StartTimer
    	hours = 11 : minutes = 30: seconds = 0
    Start:
    	LCDOUT $FE,1                    ' Initialize LCD
    	PAUSE  200
    	lcdout $fe,2,"Starting ..." : pause 500
    	serin2 gps,188,1000,no_gps,[wait("MC"),str rmc\15\10]	'15 bytes only for testing () wait for RMC message
    	lcdout $fe,$c0,"Time : ",dec2 hours,":",dec2 minutes,":",dec2 seconds
    	lcdout $fe,2,"$",str rmc\15 :pause 500						' these are the bytes as captured !
    no_gps:
    	lcdout $fe,2,"Np Gps stream ": pause 500
    	goto  main
    my first idea to fix it,was stop the timer just before get the gps data stream, like this:
    	gosub stoptimer
    	gosub starttimer
    using above lines my LCD looks like this:
    looks good !!!
    but here, I have a problem with the time !, this make delay on the RTC, If I just was updated my clock register each ten minutes or so, that work out very well, but I want to keep my RTC all the time, (for logging timed-stamp GPS locations by example).
    I knew this is a time issue (software generated timing "serin2"), another plan is to use the internal UART build in my pic (i'm using a18f452), but my GPS only outputs TTL levels this create interfacing problems, how can I get working this project?
    Thanks !!!
    Quote Originally Posted by bethr View Post
    Probably the interrupts interrupting the SERIN statements. Disable the interrupts before going into SERIN, reenable after coming back.
    Normal, Inverted RS232, the PICs capabilities, all discussed fairly well in the PBP manual.
    Since you're using a GPS, you already have a clock that's more accurate than anything you could possibly add to a PIC.
    Just read the GPS time to use as a time stamp in the logs.
    OR, a single transistor with 2 resistors can invert the serial data to the USART, if you still want the internal clock.
    OOPs.
    I just looked up the 188 from your SERIN2 statement.
    That's 4800 baud TRUE levels.
    You can hook it up to the USART's RX pin. No transistor needed.
    hth,
    Jul 2006
    Thanks by answer Skimask, Darrel !
    you both Are right, there is no interfacing conflicts, but unfortunately I always get the ' no gps ' string on the LCD (with or without running the RTC), I mean, I have made changes for using Hserin instead serin2,
    	DEFINE HSER_TXSTA 20h
    	DEFINE HSER_RCSTA 90h
    	DEFINE HSER_BAUD 4800
    		j    var byte
    		led1 var  portb.2
    		b0   var byte
    		adcon1 =$07
    		trisa.2 = 0
    		trisa.4 = 1
    		trisb.1 = 1
    		trisb.2 = 0
    		trisb.0 = 1
    		trisc.2 = 0
    		trisc.7 = 1
    	    porta.2 = 0
    		gps var portb.1
    	 	spk    var portc.2
    init:
    	INT_CREATE
    	GOSUB ResetTime
    	GOSUB StartTimer
    Start:
    	PAUSE  200
    	Hserin 1500,no_gps,[wait("MC"),str rmc\15\10]	'15 bytes only for testing () wait for RMC message
    no_gps:
    	lcdout $fe,1,"No Gps stream "
    	goto  main
    currently for debug I'm using an GPS software simulator:
    and I'm sure that it works, this is a debug rs232 window (hyperterm)
    that was taken on Sub-DB9 connector of the picdem2 board
    there is something missing in the set-up hardware UART ???
    Thanks again !
    Try it like this...
    	DEFINE HSER_TXSTA 24h ' BRGH=1
            DEFINE HSER_CLROERR 1 'Hser clear overflow automatically
    Jul 2006
    Smile
    It's alive !!
    it works Darrel, I'm wondered why this bit must be set in hi speed if my bps is low ! (4800 bps)
    bit 2 BRGH: High Baud Rate Select bit
    Asynchronous mode:
    1 = High speed
    0 = Low speed
    and now it looks run pretty ! (with RTC running ), look this:
    Now, I'll keep it running for a while, I hope the RTC doesn't have long-delays. any-way as you said, always there is way to update ths RTC register with GPS ones !!
    BTW currently I'm not using UART interrupts, but . . .
    . . . what if . . .
    I enable it ?, this give more reliable data incoming form the GPS line ? or it can be dangerous for the RTC health ?
    It's alive !!
    WooHoo!
    With a 4mhz OSC, I wouldn't consider 4800 "low".
    In the datasheet there's a couple tables that show the baud rates vs. OSC freq with BRGH either 1 or 0. With BRGH=0 @ 4mhz, the highest baudrate in the table is 2400. With BRGH=1 it's 19200.
    It may still work with BRGH=0, but it's close to the edge, so why not just make it BRGH=1.
    I think the HSER_CLROERR 1 may have had the biggest effect.
    The GPS will just spit out the data at regular intervals. It doesn't wait for the PIC to be ready. And at 4800 baud it can send a byte every 2ms. So when the program sits in a 500 ms pause, it may receive a couple hundred bytes before the program gets around to looking at the data. There's only a 2 byte buffer in the USART so it causes an Overflow that must be cleared before it will start receiving data again.
    . . . what if . . .
    HSERIN is not compatible with USART interrupts.
    You would need to parse the incomming data 1 byte at a time with your own handlers.
    It's much easier to use HSERIN.
    hth,
    Jul 2006
    Talking
    Yes you're Right, I think that on this way the gps clock work well, there is no problem with it, I have it running & all looks nice !
    The program doesn't anything important (just led blinking), and when BTN rb0 is pushed, it gets info from GPS module and update my RTC registers just as i wanted !
    'BETHR
            DEFINE HSER_CLROERR 1 			' Hser clear overflow automatically
    	DEFINE HSER_SPBRG 51
    ''''''''''''' VARS ''''''''''''''''''''''''''''''''''''
    		led   var Portb.2
    		timeh var byte
    		timem var byte
    		times var byte
    		day	  var byte
    		mon   var byte
    		yr    var byte
    		stat  var byte
    		gps   var Portb.1
    		TRISB.2 = 0
    		TRISB.0 = 1
        	         Adcon1 = $07
    init:
    	INT_CREATE
    	Gosub ResetTime
    	Gosub StartTimer
    	hours = 12 'after reset we always star @12:00:00
    Start:
    	lcdout $fe,1,"GPS Clock "
        Pause 500
    	While 1
    'do something [  something more useful than this :-)  ]
    		While (portb.0=1)
    			Toggle led
    			Lcdout $fe,2,"Date : ",dec2 day,47,dec2 mon,47,dec2 yr
    			Lcdout $fe,$c0,"Time : ",dec2 hours,":",dec2 minutes,":",dec2 seconds
    		 	Pause 200
    		Wend
    ' if i press rb0 btn update my RTC
    		Gosub Update_rtc
    	Wend
    ''' SUBS ''''
    Update_rtc:
    'look 4 stream
    	lcdout $fe,1,"Updating..."
    	Hserin 500,no_gps,[WAIT("MC,"),dec2 TIMEH,dec2 TIMEM,dec2 TIMES,SKIP 5,_
    	STAT,skip 30,dec2 day,dec2 mon,dec2 yr]
    'check 4 Valid GPS if so, then update my RTC
    	if stat = "A" then
    		hours=timeh - 5 : minutes = timem: seconds = times
    'no gps so don't update
    		lcdout $fe,1,"Bad Fix" : pause 500
    'np gps or bad sintax
    no_gps:
    	lcdout $fe,1,"No Gps stream" : pause 500
    ''' END SUBS ''''
    I've had to replace my broken LCD also !!
    BIG TNX !
    Jan 2007
    Houston, TX
    Default GPS info
    Hi there Bethr,
    I am looking at purchasing a garmin LVS gps for a robot project and I was just wondering what kind of gps you are using? Cost? etc....
    Padawan-78
    Quote Originally Posted by earltyso View Post
    Hi there Bethr,
    If it has an NMEA serial output line, then you can get usable data out of it.
    www.sparkfun.com has a few GPS modules already mounted, ready to use.
    Jul 2006
    Hi there Bethr,
    currently I have two modules
    this:
    http://www.trimble.com/embeddedsyste...?dtID=overview
    and this one , a low profile asian embedded device:
    both were removed from used equipment, but I know that the trimble module have a cost near to 50 usd (versus qty)
    and the other one near to 30 usd
    both devices has NMEA ascii output @t vdd levels, trimble vdd=3v3 and asian device vdd=5v
    Cheers !!
  1. GPS $GPRMC to PIC16F684. Need help with SERIN2
    Last Post: - 27th November 2009, 10:47
  2. Shiftout/in
    By BobEdge in forum mel PIC BASIC Pro
    Last Post: - 23rd August 2007, 12:48
  3. Help with sound command in 2 programs
    Last Post: - 5th July 2007, 21:36
  4. Replies: 2
    Last Post: - 28th April 2006, 13:10
  5. GPS Receiver
    By lester in forum Adverts
    Last Post: - 22nd February 2006, 13:47
