How can I adjust in USBDemo A/D converter from 8 to 10 Bit resolution?
Results 1 to 10 of 10
    There are 2 parts to Steve's USBdemo.
    The PicBasic Pro program for the PIC, and a visual basic program for the PC.
    It would have to be changed on both ends.
    I can show you how to change it on the PIC side. But I don't do Visual Basic.
    Apr 2008
    Default How can I adjust in USBDemo A/D converter
    If you show me how to change it on the PIC side, it's enough. For Visual Basic I will find way to change it.
    Kuba230
    USBDemo
    ' File name : USBDemo.pbp
    ' Company : Mister E
    ' Programmer : Steve Monfette
    ' Date : December 30,2006
    ' Device : PIC18F4550 & 4MHZ crystal
    ' Short and sweet demo to send and read from USB bus.
    ' Hardware:
    ' 4 Push Buttons on PORTA<5:2> with pull-down resistors
    ' 2 Trim pot on PORTA<1:0>
    ' 8 LEDs attach between PORTB and GND
    ' 2 LEDs attach to CCP<2:1> pins
    ' 4 MHZ crystal & all the usual USB stuff
    ' Software:
    ' A ready to run PC interface is also available, it's VB6 source code as well
    ' Enjoy!
    ' Pic Configuration
    asm
    __CONFIG _CONFIG1L, _PLLDIV_1_1L & _CPUDIV_OSC1_PLL2_1L & _USBDIV_2_1L
    ; ; ; USB clock source comes from the 96 MHz PLL divided by 2
    ; ; [OSC1/OSC2 Src: /1][96 MHz PLL Src: /2]
    ; No prescale (4 MHz oscillator input drives PLL directly)
    __CONFIG _CONFIG1H, _FOSC_XTPLL_XT_1H & _FCMEN_OFF_1H & _IESO_OFF_1H
    ; ; ; Oscillator Switchover mode disabled
    ; ; Fail-Safe Clock Monitor disabled
    ; XT oscillator, PLL enabled, XT used by USB
    __CONFIG _CONFIG2L, _PWRT_ON_2L & _BOR_ON_2L & _BORV_2_2L & _VREGEN_ON_2L
    __CONFIG _CONFIG2H, _WDT_OFF_2H
    __CONFIG _CONFIG3H, _MCLRE_ON_3H & _LPT1OSC_OFF_3H & _PBADEN_OFF_3H & _CCP2MX_ON_3H
    __CONFIG _CONFIG4L, _STVREN_ON_4L & _LVP_OFF_4L & _ICPRT_OFF_4L & _XINST_OFF_4L & _DEBUG_OFF_4L
    endasm
    DEFINE OSC 48
    Define ADC_BITS 10 ' Set number of bits in result
    Define ADC_SAMPLEUS 20 ' puvodni (50) Set sampling time in uS
    ' Hardware configuration
    ' I/O and PORTs
    PORTB = 0
    PORTC = 0
    PORTD = 0
    PORTE = 0
    TRISB = 0
    TRISC = 0
    TRISA = $FF
    TRISD = 0
    TRISE = 0
    ' A/D converter
    ADCON0 = %00000001 ' A/D converter on, CH0 selected
    ADCON1 = %00001101 ' AN<1:0> Analog, other digital
    ADCON2 = %10010110 ' FOSC/64, 4 TAD, right justified
    ' CCP/PWM
    CCP1CON = %00001100 ' CCP1, PWM mode
    CCP2CON = %00001100 ' CCP2, PWM mode
    PR2 = 249 ' 12khz PWM Freq
    T2CON = %00000101 ' TMR2 on, prescaler 1:4
    ' USB module
    UCFG var byte EXT ' include UCFG register... Yeah Melabs didn't (
    ucfg = %00010100 ' enable internal USB pull-up, Full speed USB
    ' Interrupt definition
    ' TMR0 interrupt used to keep USB connection alive
    ' by sending USBSERVICE at each 100uSec or so.
    INTCON = %10100000 ' Enable global and TMR0 interrupts
    T0CON = %10000000 ' TMR0, CLK internal, prescaler 1:2, T0ON
    ' Variables & constants definition
    USBBufferSizeTX con 8 ' input
    USBBufferSizeRX con 8 ' output
    USBBufferCount Var Byte '
    USBBufferIn var byte[8] ' store incomming USB data
    USBBufferOut Var Byte[8] ' store outgoing USB data
    DataToSend var byte[8] ' store ADCs & pushButton data to send to USB
    String1 var byte[8] ' hold 'USB DEMO' string
    string1[0]="U"
    string1[1]="S"
    string1[2]="B"
    string1[3]=" "
    string1[4]="D"
    string1[5]="E"
    string1[6]="M"
    string1[7]="O"
    @ADRead = ADRESL ; use to read both ADCs register in one shot
    ADRead VAR WORD EXT ' make it available to use in PBP
    @Duty1=_USBBufferIn+1 ; use to read both Duty bytes from specifics
    @Duty2=_USBBufferIn+3 ; USBBufferIn locations in one shot
    Duty1 var word EXT ' make them available
    Duty2 var word EXT ' to use in PBP
    ' Constants definition
    TMR0IF VAR INTCON.2 ' TMR0 overflow int flag
    TMR0ON VAR T0CON.7 ' TMR0 on/off bit
    TMR0IE VAR INTCON.5 ' TMR0 interrupt enable/disable bit
    GoDone var ADCON0.1 ' ADC conversion
    ' Macro(s) definition
    goto SwHwInit ' skip macros
    asm
    Reload_TMR0 macro
    ; Use to stop, reload, clear overflow flag and restart TMR0
    BCF _TMR0ON ; stop timer
    MOVE?CW d'65000',TMR0L ; reload for timebase ~100uSec
    BCF _TMR0IF ; clear overflow flag
    BSF _TMR0ON ; start timer
    ENDM
    SendUSB macro array
    ; Use to Copy an specific array to USBBufferOut AND send it
    ; to USB bus
    variable i=0
    while i<8
    MOVE?BB (array+i),(_USBBufferOut+i)
    i+=1
    endw
    L?CALL _DoUSBOut
    endasm
    ' Software/Hardware initialisation
    SwHwInit:
    pause 500 ' Settle delay
    usbinit ' initialise USB
    @ Reload_TMR0 ; Reload timer0
    ON INTERRUPT GOTO DoUSBService
    ' Main program start
    Start:
    ' Here we will check the status of push buttons on PORTA<5:2>
    ' do adc conversion on AN0 and AN1 and send everything to
    ' the USB bus
    ' DataToSend[0&1]: AN0, AN1 8 bits ADC results
    ' DataToSend[5:2]: PORTA<5:2> status
    ' Look if there's any push button pressed, if so, send String1
    ' to USB bus
    if (PORTA>>2)!=0 then
    @ SendUSB _String1
    ' Do ADC conversion and save it to specific DataToSend array
    ADCON0.2=ADCON0.2 ^ 1 ' Switch between AN0 & AN1
    PAUSEUS 10 ' arbitrary SamplingTime
    GODONE=1 ' start conversion
    WHILE GODONE : WEND ' wait 'till finish
    DATATOSEND[ADCON0.2]=(ADREAD>>2) ' save it to DataToSend array
    ' Read pushbutton status and save it to DataToSend array
    datatosend[2] = PORTA.2
    datatosend[3] = PORTA.3
    datatosend[4] = PORTA.4
    datatosend[5] = PORTA.5
    datatosend[6] = 0
    datatosend[7] = 0
    ' Send data to USB bus
    @ SendUSB _DataToSend
    ' Check if there's any incomming data
    gosub dousbin
    ' Redo from start
    goto start
    ' Subroutines area
    DoUSBIn:
    ' Check and receive data from the USB bus
    ' USBBufferIn[0] : PORTB led status
    ' USBBufferIn[1&2]: CCP1 PWM duty cycle LSB first (Duty1)
    ' USBBufferIn[3&4]: CCP2 PWM duty cycle LSB First (Duty2)
    tmr0ie = 0 ' disbale TMR0 int
    USBBufferCount = USBBufferSizeRX ' RX buffer size
    USBService ' keep connection alive
    USBIn 1, USBBufferin, USBBufferCount, Timeout ' read data, if available
    Timeout: '
    @ Reload_TMR0
    tmr0ie = 1 ' re-enable TMR0 int
    PORTB = USBBUFFERIN[0] ' output to PORTB
    CCP1CON.5=DUTY1.1 ' load CCP1 duty value
    CCP1CON.4=DUTY1.0 ' with Duty1
    CCPR1L=DUTY1>>2 '
    CCP2CON.5=DUTY2.1 ' load CCP2 duty value
    CCP2CON.4=DUTY2.0 ' with Duty2
    CCPR2L=DUTY2>>2 '
    DoUSBOut:
    ' Send data to the USB bus & Wait for USB interface to attach
    TMR0IE = 0 ' Disable TMR0 interrupt
    WaitPC: '
    USBBufferCount = USBBufferSizeTX ' TX buffer size
    USBOut 1, USBBufferOut, USBBufferCount, Waitpc ' if bus available, transmit data
    @ Reload_TMR0
    tmr0ie=1 ' Re-Enable TMR0 interrupt
    DISABLE
    DoUSBService:
    usbservice ' keep connection alive
    @ Reload_TMR0 ; reload timer
    RESUME ' getout of here
    ENABLE
    Steve was controlling the A/D converter manually. So adding the ADC_ DEFINE's won't have any effect.
    He was also getting a bit tricky (in a good way), so this might seem a little odd too.
    ;    DATATOSEND[ADCON0.2]=(ADREAD>>2)    ' save it to DataToSend array
        DATATOSEND[ADCON0.2*2]=ADREAD.LowByte
        DATATOSEND[ADCON0.2*2+1]=ADREAD.HighByte
        datatosend[4] = PORTA.2
        datatosend[5] = PORTA.3
        datatosend[6] = PORTA.4
        datatosend[7] = PORTA.5
    ;    datatosend[6] = 0
    ;    datatosend[7] = 0
    With the above changes, the packet being sent will have AN0 in the first 2 bytes, 0 is the lowbyte.
    AN1 is in bytes 2 and 3. and the pushbutton status is moved to bytes 4-7.
    Hope you can move things easily on the VB side.
    hth,
    Apr 2008
    Default How can I adjust in USBDemo A/D converter from 8 to 10 Bit resolution?
    Hi Mr. Taylor,
    I did not tray still your advice for modification of USBDemo program, because I take my holiday. When I com back, then I will try.
    Kuba230
    Apr 2008
    Hi Mr. Taylor,
    I made changes of USBDemo picbasic code according your advice and after compilation I obtain error messages:
    Error[113 ] c:\pbp_prog\usbdemo.asm 61 : Symbol not previously defined (ADRead)
    Error[113 ] c:\pbp_prog\usbdemo.asm 62 : Symbol not previously defined (ADRead)
    I do not know why is happen?
    Kuba230
    Oops, I should have compiled it first.
    Try these 2 lines instead...
        DATATOSEND[ADCON0.2*2]=ADRESL
        DATATOSEND[ADCON0.2*2+1]=ADRESH
    Apr 2008
    Default Two 10 Bits channels in USBDemo
    Hi Mr. Taylor,
    I did those changes to display 10 Bits value in Visual Basic program for USBDemo, it works perfectly, but only for one channel, AN0. What I have to change in picbasic USBDemo program to obtain two 10 Bits channels, AN0 and AN1?
    ;incomming ADC reading and PORTA status
    ;pAN0.Value = BufferIn(1) ' Display ADC results to the progress bars
    pAN0.Value = Val(BufferIn(1)) + Val(BufferIn(2)) * 256 'Display ADC for AN0
    ;pAN1.Value = BufferIn(2) ' Display ADC results to the progress bars
    ;lValAN0.Text = Val(BufferIn(1)) ' Display Progress bars Values
    lValAN0.Text = Val(BufferIn(1)) + (Val(BufferIn(2)) * 256 'Display ADC for AN0
    ;lValAN1.Text = Val(BufferIn(2)) ' Display Progress bars Values
    Note:
    Also is necessary to change maximal value of progressbar properties pAN0 from 255 to 1023
    Kuba230
  1. How do I use 10 bit A/D on 8 bit Pic? 12F675
    By polymer52 in forum mel PIC BASIC Pro
    Last Post: - 1st April 2020, 20:10
  2. MCP3208 12 bit A/D driver
    By polymer52 in forum Code Examples
    Last Post: - 5th February 2010, 11:59
  3. PICBasic newbie problem
    Last Post: - 12th February 2008, 00:55
  4. A/D converter fails?
    By egberttheone in forum mel PIC BASIC Pro
    Last Post: - 13th February 2006, 18:57
  5. Need help with 16f819 10 bit ADC
    By bannrikae in forum mel PIC BASIC Pro
    Last Post: - 26th September 2005, 15:20
