C vs PBP
Results 1 to 16 of 16
Thread: C vs PBP
    Default C vs PBP
    Hello Everyone,
    I was looking at a C program from nuts & volts and it contained a lookup table, in it were bytes laid out like this 0b0000000, or 0b1100000 . . . and apparently these seem to be oposite of the PBP way of writing them, whereas 0b1100000 is equiv. to %00000011. Is this correct ?
    Thank You
    JS
    Default Endians
    Ok I found my answer, it's about Big Endians and Little Endians, in other words C uses both according to who's C it is and some will use either! Which is to say some list binary MSB first and others list LSB first, what I would like to know now is how to tell them apart, I notice some list 0x00000000 and some list 0b00000000, does anyone know, is that how to identify them?
    For single byte data types, 0b11000000 should be the equiv. of %11000000 in PBP. As far
    as "I" know, most C compilers will store byte values as entered. If would really get to be
    confusing if you had LSB/MSB of single byte values swapped around in words, longs, unions,
    etc.
    Endianess normally comes into play when you're dealing with multi-byte data types like longs,
    words, etc. Then you may, or may not, need to know how these are stored in data memory.
    With PBP MyVar VAR WORD, MyVar =$AABB would be stored little-endian. I.E. if the address
    of MyVar starts at 30h, then $BB will be stored at 30h followed by $AA at 31h. C18, HiTech,
    and CCS compilers work the same. Some have a compile-time switch you can use to change
    byte ordering to big-endian.
    In C, when you start dealing with unions, you'll definitely want to know the ordering of bytes
    in multi-byte values. The compiler manual should have all that neat stuff.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Here is the code I was eyeballing, From Nuts and Volts Aug 2007, a water heater controller, display section,
    ////////////////// Display.c //// for PIC16F684 using MPLAB IDE 7.51
    //       PICC Compiler with PICSTART Plus programmer
    //       by Dick Aidt  7 Mar 07   //
    //       Program displays the digits sent by the Thermal program
    #include <pic.h>
    #include <math.h>
    __CONFIG(INTIO & WDTDIS & PWRTEN & MCLRDIS & UNPROTECT &\
    UNPROTECT & BORDIS & IESODIS & FCMDIS);
    const char LEDDigit[ ] =
     { 0b0000001,                  //  "0"
        0b1001111,                  //  "1"
        0b0010010,                  //  "2"
        0b0000110,                  //  "3"
        0b1001100,                  //  "4"
        0b0100100,                  //  "5"
        0b0100000,                  //  "6"
        0b0001111,                  //  "7"
        0b0000000,                  //  "8"
        0b0001100,                  //  "9"
        0b0001000,                  //  "A"
        0b1100000,                  //  "B"
        0b0110001,                  //  "C"
        0b1000010,                  //  "D"
        0b0110000,                  //  "E"
        0b0111000  };              //  "F"
    int  Value=0;
    int Dig [ 4 ];
    int i=0,t=0, x = 0, y = 0, z = 0;
    int in = 0;	// built up inputed data Temp
    int s = 0;	// recieved bit
    const j[ ]={0,1,0,1};
    const k[ ]={0,0,1,1};
    main(void)
    	CMCON0 = 7;			//  Turn off comparators
    	ANSEL = 0;			//  disable  analog
    	PORTA = 0b00001100;
    	TRISA = 0b00001100;		//  RA2 & RA3 are inputs
    	PORTC = 0;
    	TRISC = 0b00000000;		//  PORTC is all outputs
    ADC:	if (!RA3)
    		in = 0;
    		for ( i = 0; i < 12; i ++)
    			while ( ! RA3) //wait for HI sync pluse
    				{NOP();}
    			{ s = RA2; in = (in | ( s << i));} // get the bit
    			while (RA3) //wait for LO sync pluse
    				{NOP();}
    		} // get next bit
    		while ( ! RA3) // wait for HI sync pluse
    		NOP();
    		Value = 0;
    		Value =  in;	// make display numbers array
    		if (Value < 1000)
    			{	z = 1;
    				Dig [ 0 ] = 0;
    				goto JUMP1;
    		else z = 0;
    			NOP();
    		Dig [ 0 ] = Value/1000;
    JUMP1:	Dig [ 1 ] = Value / 100 - (Dig[0] * 10);
    		Dig [ 2 ] = Value / 10- (( Dig[0] * 100 )+ ( Dig[1] * 10 ));
    		Dig [ 3 ] = Value  - (( Dig[0] * 1000 )+ ( Dig[1] * 100 ) +( Dig[2]*10));
    	for (y=0; y < 4; y++) // Display the digits
    		if ( y == 0 & z == 1 )
    			 y = 1;// if F < 100 skip first digit
    		PORTC = LEDDigit [ Dig [ y ] ];
    		RA5 = LEDDigit [ Dig [ y ] ] >> 6;
    		RA0 = j [ y ];		//select which digit
    		RA1 = k[ y ];
    		if  (y == 2)
    			RA4=0; // turn on decimal point
    		else RA4=1;
    		NOP();
    		for (t=0; t<327; t++);// display delay
    		NOP();
    	} // end for
    	PORTC = 0b11111111;
    	RA5 = 1;
    	goto ADC;
    } // End
    Notice the lookup table for the digits.
    It's tough to say what he's doing without a schematic. Do you have a link to one?
    Definitely appears to be Hi-Tech C compiler.
    -Bruce
    tech at rentron.com
    Hi Bruce, I emailed the link to the pdf to tech at rentron dot com. Thanks for looking.
    I would have PM ed but . . .
    JS
    Hi Joe,
    Could you send me that link again? For some reason I didn't get the first one.
    -Bruce
    tech at rentron.com
    I have done so. Thank You
    EDIT:
    I think I am beginning to see, he has switched up the segments to ports in reverse order and taken 2 of them to another port altogether. RC5 = B, RC4 = C, RC3 = D . . . so Why does the C language list binary in 2 different formats, I. E. 0x00000000, and 0b00000000 ?
    I couldn't download the schematic, but that does look like what he's doing by just looking
    at the source code. This would be a lot easier with all 7-bits on a single port.
    It varies from one compiler to the other. C18, CCS and Hi-Tech use the 0b00000000 format.
    0x is normally for HEX numbers. CCX5 uses 0b.0000.0000 format for binary.
    -Bruce
    tech at rentron.com
    I think this translates over to PBP. I could be completely wrong.
    'config statements to be fixed up
    leddigit var byte[15]:value var byte:dig var byte[4]:i var byte:t var byte
    x var byte:y var byte:z var byte:in var byte:s var byte:j var byte[4]
    k var byte[4]:j[1]=1:j[3]=1:k[2]=1:k[3]=1:for i=0 to 15
    lookup i,[1,59,18,6,72,36,32,15,0,12,8,96,49,66,48,56],leddigit[i]:next i
    main: cmcon0=7:ansel=0:porta=12:trisa=12:portc=0:trisc=0
    ADC:
    if porta.3 = 0 then
         in = 0:for i=0 to 12:while porta.3=0:wend:s=porta.2:in=in|(s<<i)
         while porta.3=1:wend:next i:while porta.3=0:wend:value=in:z=0
         if value < 1000 then z=1:dig[0]=0:goto jump1
         dig[0] = value / 1000
    JUMP1: dig[1]=value dig 3:dig[2]=value dig 2:dig[3]=value dig 1:dig[4]=value dig 0
    for y = 0 to 4
         if y = 0 and z = 1 then
              y=1:portc=leddigit[dig(y)]:porta.5=leddigit[dig(y)]>>6:porta.0=j[y]
              ra1=k[y]:porta.4 = y.1:for t = 0 to 327 : next t
    next y:portc=$ff:porta.5=1:goto adc
    Oh...and it's been colonized!
    Thanks Bruce,
    I did manage to remember how to make a copy of the schematic, you answered most of my question. I did visit 1 web site dedicated to C programming which stated that some C compilers could use both Endians styles, so that was some of my confusion.
    Last edited by Archangel; - 4th July 2008 at 03:44. Reason: try to display attachment
    ADC:
    if porta.3 = 0 then
    for y = 0 to 4
    Hi Jeremy,
    I wasn't trying to translate this, but thanks! I was trying to figure out the unusual way the lookup table was set up. Seems the author was "thinkin' outside the box" So I learned something, which is my objective here. Seems I ticked off Darrel, so whatever he had to show me is history, I didn't expect him to sit and write me a program, but he did, . . . so if your reading this Darrel, I apologize . . . anyway Thanks Jeremy, and Bruce, I got a grip on why this piece of code is written this way. <br> I will play with this "colony" to extract what I might learn from it. I think what bugs people about the colons is it makes it hard to distinguish colons following a LABEL vs colons denoting a new line of code.
    Hi Jeremy,......I wasn't trying to translate this, but thanks!
    I was just playin' around a bit, translation and all. I've got no idea if it's correct or not.
    And like I've said before, the only reason I like the colons is because it keeps more info on one page. As far as LABELs vs. multiple statements...kinda easy to tell the difference because a LABEL isn't a statement at the beginning of a line, can't be, otherwise it'd kick out an error.
    Stop that.
    No, I'm sorry Joe. ... Sort of.
    When it became apparent you would be using a different program. I kept what I had, improved it, and sold it.
    Should make bunches, I hope.
    No bad blood here!
    Stop that.
    No bad blood here!
    I hope you did ! Nothing would make me happier than to see you prosper, Damn well you deserve to ! Happy Independence Day ! And to everyone who responds to my posts, Thank You!
    Nothing is obvious when you are confused!
  1. PBP Book
    By Bruce in forum Off Topic
    Last Post: - 4th October 2021, 13:55
  2. PBP, ASM and LST files
    By HenrikOlsson in forum mel PIC BASIC Pro
    Last Post: - 12th January 2010, 14:43
    Last Post: - 2nd May 2006, 20:01
    Last Post: - 18th December 2005, 00:30
  5. PBP / XP Crash
    By pondindustrial in forum mel PIC BASIC Pro
    Last Post: - 27th November 2005, 04:16
