another phase of the finished project
http://www.picbasic.co.uk/forum/showthread.php?t=5757
will be the the wireless video transmitting .
using a 1.2 ghz RX/TX the receiver will always be powered up and the transmitter power up when needed.
what I need is A output @ the receiver WHEN IT IS receiving . to use as a input on a 12f629
What I 'm looking @ is using a NE567 tone decoder chip @ the receiver audio output, set for X freq. and feeding the transmitter audio input using "Freqout" from the 16f676 on my main board with the filter diagram in the PBP manual which also says
"FREQOUT works best with a 20MHz or 40MHz oscillator. It can also work
with a 10MHz oscillator and even at 4MHz, although it will start to get
very hard to filter and be of fairly low amplitude."
I'm using the enternal 4MHz clock
I guess what I'm asking is
1. will this work?
2. is there a better way?
3. how would you do it?
4. can this be done PIC to PIC without the decoder
as always thanks
