About writing word variables into the eeprom
Results 1 to 12 of 12
    When you say efficient, do you mean speed or code size?
    If you alias the Word array as a Byte array, you can just write 1 byte at a time in the loop.
    arraysize  CON 20
    Array      VAR WORD[arraysize]
    @ByteArray = _Array
    ByteArray  VAR BYTE EXT
    FOR ArrayPosition = 0 TO (arraysize*2-1)
        WRITE ArrayPosition, ByteArray(ArrayPosition)
    NEXT ArrayPosition
    Ted's's Avatar
    Ted's Guest
    The latter.
    I've only done this once a while back but all I did in my program at WRITE time is:
    WRITE 0,X.BYTE0 : WRITE 1,X.BYTE1
    At READ time:
    READ 0,X.BYTE0 : READ 1,X.BYTE1
    I don't remember having any problems. Hope it works.
    Ted's's Avatar
    Ted's Guest
    It does.
    You know, the issue here is filling the eeprom with data from a word array. Your line is only a part of it.
    Ted's's Avatar
    Ted's Guest
    arraysize  CON 20
    @ByteArray = _Array
    NEXT ArrayPosition
    I do not understand your code. Please comment.
    This should help some.
    Once you know what the EXT modifier does, it should make more sense.
    The EXT (external) modifier.
    http://www.picbasic.co.uk/forum/showthread.php?t=3891
  1. Read/Write Problem
    Last Post: - 10th February 2010, 02:51
  2. Minimizing code space
    Last Post: - 30th May 2009, 08:25
  3. DS2760 Thermocouple Kit from Parallax in PicBasicPro
    By seanharmon in forum mel PIC BASIC Pro
    Last Post: - 9th July 2008, 00:19
  4. calculation problem
    Last Post: - 31st March 2006, 16:23
  5. word variable to 25lc640
    Last Post: - 6th July 2004, 20:59
