RS232 into 2 PC ports
Results 1 to 3 of 3
    Isle of Man
    Cool RS232 into 2 PC ports
    I have a serial connection from a MAX232 on my PIC board to an RS232 port on my PC. The data are used in a PC graphics and PIC-control application, using both the TX and RX lines.
    Is there any reason why I cannot split the RX line at the PC into 2 so that I can feed a second RS232 port on the computer? The reason for this is that I want to run a completely separate PC data processing application. The TX control line would remain connected to the other PC RS232 port, for control over the PIC.
    Bombay, India
    You can share the RX line on the PC with another. Both will get the same data from your PIC.
    Isle of Man
    Wink Sharing RS232
    Jerson,
    Thanks for that advice. My problem is solved!
  1. PIC18F4680 to PC via MAX232 (RS232 serial) no output
    By opticsteam1 in forum mel PIC BASIC Pro
    Last Post: - 14th April 2008, 21:39
  2. Microcontroller with 2 way paging application problem
  3. PC to PIC via RS232
    By Martin.... in forum mel PIC BASIC
    Last Post: - 15th September 2006, 11:44
  4. Pic18F4455 to PC communication RS232
    By anmproj in forum mel PIC BASIC Pro
    Last Post: - 30th July 2005, 03:32
  5. data from pc thru rs232 via 16f877 to 24c256 on-the-fly
    By agucollins in forum mel PIC BASIC
    Last Post: - 24th March 2005, 18:26
