Problem to compile my program
Results 1 to 6 of 6
Threaded View
    Jul 2008
    Default Problem to compile my program
    I am an user of Proton and I have a problem that I dont know how to solve it.
    Proton compiles my program normally but when start the asm compiler I have the result that you can see in the attached file. what I must to do to solve it?
    The BASiC program is OK. If I remove the USB rotine the program compile the basic part and after the asm part. But When I insert the USB rotine, the basic compiler normally but the asm part show the problem of the "Out of range".
    I have the PROTON IDE I update the compiler, by on line update but I dont find the problem.
    I am using PIC 18F4550 USB port active. The program has 2200 lines.
    I can see that the problem is in the PBP file, line 1110 I have the instruction:
    "rcall initialiseusb@driver"
    Thank you in advance
    Wagner
  1. Compile and Program help using PICKit2
    By ozarkshermit in forum mel PIC BASIC Pro
    Last Post: - 10th March 2009, 15:51
  2. confused problem with interrupt in a working program
    By illuminator4 in forum mel PIC BASIC Pro
    Last Post: - 14th November 2008, 18:01
  3. Making Program Code Space your playground...
  4. PIC18F452 Compile Problem
    By scottl in forum mel PIC BASIC Pro
    Last Post: - 21st October 2006, 11:47
  5. serial program and sensor problem
    By win_832001 in forum mel PIC BASIC Pro
    Last Post: - 10th April 2006, 05:16
